Best manner to mount oil pressure sensor, Mine broke off |
HansJan |
Jan 10 2021, 09:24 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
So I suddenly lost all oil pressure doing 70 on the freeway.
After pulling of at next exit I find that the tube to the pressure sensor has broken off and let all oil spray out (no oil left in the engine). At the moment I have to find a way to get the remaining piece of pipe out of the engine block, without dropping brass chips in the block. I could then get another brass tube and reinstate it. However, it might be better to come with a way where the oil tube is not also responsible for keeping the sensor in place. I’m thinking of making a short hose of some kind and creating a mounting bracket to the sensor somehow. Would you be so kind to show me your solution? |
GregAmy |
Jan 11 2021, 08:59 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
It's an M10 tapered, but 1/8" NPT will seal fine.
On the other hand, it's a simple matter to run a 1/8" NPT tap in there, greased liberally to snag the small chips. I do not like fixed mounts, for reasons stated above. I know that people have used it successfully but there's a reason that it's not acceptable for aircraft (and you experienced why). The flex hoses are not expensive, and the sensors are easy to mount on the cooling tin. |
Lo-Fi Version | Time is now: 12th June 2024 - 01:15 AM |
