How to fix leaky fuel injector, Not finding a lot of help on the web |
boxster914 |
Jan 10 2021, 11:19 PM
Member Group: Members Posts: 74 Joined: 17-September 20 From: NC, USA Member No.: 24,700 Region Association: South East States |
My 71 Irish Green 914 has a leaky fuel injector. I would try to fix it but I am not finding a lot out there on how to fix it.
Here is a video of the leak as I turn the ignition on: https://youtu.be/Ts1pcdHf_kg You can see that it leaks out of the rubber boot and then drips onto the tin. Can anyone help me with how to videos or point to some resources here or somewhere on the web? You've all been great with my other problems. |
boxster914 |
Jan 11 2021, 03:31 PM
Arno914, I think you are right.
I've drawn green lines at the junction between the black gasket and the metal part of the injector where the gas is seeping out. (Why are yours yellow?) So can I just buy this: http://www.autoatlanta.com/Porsche-914-Fue...ector-srch.html and pop it in to solve the problem? |
914_teener |
Jan 11 2021, 04:49 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Arno914, I think you are right. I've drawn green lines at the junction between the black gasket and the metal part of the injector where the gas is seeping out. (Why are yours yellow?) So can I just buy this: http://www.autoatlanta.com/Porsche-914-Fue...ector-srch.html and pop it in to solve the problem? If you have one that is leaking and you have never had them cleaned and tested now would be a good time. Take all four out and send them out to be tested. There are several places that do this ....searchable here. Think I used Witchhunter. Cost about $200. The risk of a fire....it is well worth the price. The flow rates for your engine is what is important and also that the pintle is working properly and spray pattern as well. Most of the flow rates are still available IIRC. The 1.8 injector has a difference impendence so if you have D-jet you can't use those. If you Winterize your car I'd put a good additive in the tank which displaces the water in the tank. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:32 AM |
