| horizontally-opposed |
Dec 20 2020, 12:43 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None
Plans to go for a drive in my 914 this weekend were dashed by yesterday's stay-at-home alert, so I finally dug into a minor project I've been putting off: Rebuilding the car's 28-year-old audio system. While it performed well for 15-20 years, a mixture of age, heat, moisture, etc eventually caught up to it.
System goals: 1) Install a system powerful enough to be enjoyed with the top on or off; 2) maintain/improve "period correct" appearance with no head unit and, if possible, no visible speakers; 3) minimize weight; 4) avoid or minimize additional holes/etc. I'm going into this with the understanding that it's entirely possible the exercise will be futile with a 2.2-liter flat six, but I have been collecting the parts over time and figure it's worth a shot. Some of this stuff has been sitting for years and thus may not be available anymore—but plenty of alternatives are. Old system components: Pyle graphic EQ turned on/off by factory rear defrost switch Pioneer fan-cooled amplifier (~1991) Boston Acoustics four-speaker set in doors (~1991) Pioneer ducted bass wedge in passenger footwell New system components: Smartphone with a proper mount > EQ Blaupunkt five-channel parametric EQ JL five-channel amplifier JL six-speaker set for factory speaker enclosures and door ?? subwoofer in passenger footwell (prepare for now, add later) Fair warning: This thread may proceed at a glacial pace, as midlife plus a small business means my days in the garage are fairly rare in this chapter. I'm also figuring this out as I go, and will use this thread as a journal and a place to share ideas. |
| Rob-O |
Jan 13 2021, 12:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,319 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
Those mids in the adapter plate look way too deep to fit in the stock location. I’d definitely test fit that. With the mid down low like that it’s not about crushing the paper heater hose. You can actually hit the small metal tube that is protruding from the rocker AND if it misses that can still be so deep that it hits the metal panel behind that.
Jan 13 2021, 12:53 PM
Those mids in the adapter plate look way too deep to fit in the stock location. I’d definitely test fit that. With the mid down low like that it’s not about crushing the paper heater hose. You can actually hit the small metal tube that is protruding from the rocker AND if it misses that can still be so deep that it hits the metal panel behind that. Thanks for reminding me to mention: I tested this setup for clearance to the original paper hoses in my car—out the very same concerns. The JL mids present no issues with clearance. |
horizontally-opposed "Invisible" audio for the Porsche 914 Dec 20 2020, 12:43 AM
horizontally-opposed Hmm, not able to upload images.
Different browse... Dec 20 2020, 12:47 AM
Jett
Hmm, not able to upload images for some reason. H... Dec 20 2020, 09:21 AM
Krieger Sometime, depending on what I'm attempting to ... Dec 20 2020, 10:58 AM
horizontally-opposed I never read the manual, either—but I was curiou... Dec 20 2020, 11:26 AM
bbrock
But, for now, this thread is…stalled. My signal... Dec 20 2020, 11:29 AM
horizontally-opposed The mids & tweeters will easily fit into the f... Dec 20 2020, 09:43 PM
BillC
The mids & tweeters will easily fit into the ... Dec 21 2020, 09:15 AM
Hopefully this is just a silly question, but hav... Dec 21 2020, 03:49 PM
horizontally-opposed On, to system components.
Goals:
1) No head uni... Dec 20 2020, 09:53 PM
horizontally-opposed Goals with the amp are to power the six-speaker se... Dec 20 2020, 09:59 PM
bandjoey I remembered this stereo setup from some years bac... Dec 20 2020, 11:37 PM
I remembered this stereo setup from some years ba... Dec 21 2020, 12:41 AM
IronHillRestorations
I remembered this stereo setup from some years ba... Jan 11 2021, 10:29 PM
horizontally-opposed With speaker locations figured out, next up is loc... Dec 21 2020, 01:08 AM
djway The last 914 I built was like rolling around insid... Dec 21 2020, 10:33 PM
djway Well Christmas delivered me a nice 6 speaker syste... Dec 26 2020, 02:07 AM
Well Christmas delivered me a nice 6 speaker syst... Dec 26 2020, 10:52 PM
horizontally-opposed Not a huge update, but finished the rough cuts of ... Dec 26 2020, 11:03 PM
horizontally-opposed In factory enclosure, and with the speakers test f... Dec 26 2020, 11:07 PM
djway My understanding of high frequency sound waves gen... Dec 26 2020, 11:13 PM
My understanding of high frequency sound waves ge... Dec 26 2020, 11:20 PM
bbrock
My understanding of high frequency sound waves g... Dec 26 2020, 11:44 PM
BTW, I love that fancy circle cutting jig :)
... Dec 27 2020, 12:41 PM
trick-e I’ve a set of enclosed Focal tweeters, with dire... Dec 27 2020, 01:03 PM
douglastic I put a hidden system in my 68 bug .. mounted the ... Dec 27 2020, 03:38 PM
914_7T3 @horizontally-opposed
Can you share the spec on ... Jan 9 2021, 04:24 PM
Can you share the spec on the ABS plastic that y... Jan 10 2021, 03:31 PM
914_7T3
Can you share the spec on the ABS plastic that ... Jan 11 2021, 07:44 PM
windforfun I've done this in many cars. Great work! ... Jan 10 2021, 04:49 PM
IronHillRestorations Put some surface mount tweeters on either side on ... Jan 11 2021, 10:18 PM
Put some surface mount tweeters on either side on... Jan 11 2021, 11:15 PM
914forme
Also, was surprised to see JL not only recommend... Jan 13 2021, 11:46 AM
Not surprised at all with out a proper dsp you c... Jan 14 2021, 09:46 AM
horizontally-opposed Okay, back to a relatively simple but good enough ... Jan 11 2021, 11:24 PM
horizontally-opposed A bit of test fitting. May use rivets for the mids... Jan 11 2021, 11:28 PM
A bit of test fitting. May use rivets for the mid... Jan 13 2021, 11:11 AM
horizontally-opposed With the speaker enclosure plan coming into view, ... Jan 11 2021, 11:36 PM
914forme :agree: but I had also thought about building a sm... Jan 13 2021, 01:13 PM
Chris914n6 I had to flip your end result and mount the tweete... Jan 13 2021, 02:08 PM
I had to flip your end result and mount the tweet... Jan 14 2021, 09:36 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th September 2026 - 06:36 AM |
