| trick-e |
Jan 12 2021, 07:25 PM
Still Learning ![]() ![]() Group: Members Posts: 122 Joined: 7-July 12 From: Traverse City, MI USA Member No.: 14,644 Region Association: Upper MidWest
Car is stored and battery is out. Looking for a decent maintenance charger for an AGM battery. There are quite a few choices, so anyone with a good experience?
| pvollma |
Jan 13 2021, 07:50 PM
Member ![]() ![]() Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region
Car is stored and battery is out. Looking for a decent maintenance charger for an AGM battery. There are quite a few choices, so anyone with a good experience? I used a PulseTech Xtreme Charge on my airplane, which in the winter got very little use, but the few times I pulled it out, after sitting for maybe a month or two, the battery had no trouble spinning the prop. I sold the airplane last year and I've now moved the PulseTech to my 914 because the last time I tried to drive it the Odyssey PC1200 barely turned it over. I also like the fact that it comes with a short connector that can be installed on the battery posts, with a quick disconnect to the longer cable to the charger, instead of using the spring clips that seem too temporary to trust for long-term use. As the name implies, it also uses a pulsing routine to de-sulfate the battery. PulseTech |
trick-e Trickle Charger Jan 12 2021, 07:25 PM
Minerva's 914
Car is stored and battery is out. Looking for a d... Jan 12 2021, 07:37 PM
johnhora I've been using this Schumacher one on an Odys... Jan 12 2021, 07:52 PM
PlaysWithCars I had a Harbor Freight trickle charger cook one of... Jan 12 2021, 10:00 PM
mepstein battery tender junior. ~25 at flaps or amazon. wor... Jan 12 2021, 10:19 PM
rmital
battery tender junior. ~25 at flaps or amazon. wo... Jan 13 2021, 02:01 PM
bbrock
[quote name='mepstein' post='2882516' date='Jan 1... Jan 13 2021, 02:17 PM
[quote name='mepstein' post='2882516' date='Jan 1... Jan 13 2021, 02:45 PM
Mark Henry If you read the Oyddssy instructions they reccomen... Jan 13 2021, 08:45 AM
rjames
If you read the Oyddssy instructions they reccome... Jan 13 2021, 01:50 PM
trick-e
If you read the Oyddssy instructions they reccome... Jan 13 2021, 04:04 PM
VegasRacer CTEK :thumbsup: :thumbsup: Jan 13 2021, 09:49 AM
brant CTEK for me also
I've one by one replaced all... Jan 13 2021, 09:53 AM
eric9144
:agree: Jan 13 2021, 10:00 AM
Shredhead CTEK. Jan 13 2021, 12:36 PM
Andyrew I just unplug my Lithium battery when not in use a... Jan 13 2021, 04:21 PM
rjames I've been using this and no complaints so far.... Jan 13 2021, 05:00 PM
ClayPerrine I have a battery tender on all of my cars. With t... Jan 14 2021, 11:20 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th October 2026 - 04:18 PM |
