Best way to fit the mounting brackets to fiberglass bumpers? |
john77 |
Jan 20 2021, 03:54 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1611179651.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1611179652.2.jpg) Finally got the front flares welded on, metal finished, and covered with a couple of coats of epoxy primer. Before I move on to welding up the rears I want to fit the fiberglass front bumper. What's the best way to fit the brackets to the bumper... 1. Mount the brackets to the car, and then epoxy the bumper to the brackets and just hold in place with tape until the epoxy sets? 2. Test mount the bumper, mark where the brackets should be, and then attach them to the bumper off the car? (Not sure if there's even clearance behind to do this.) 3. Some obvious way I'm too stupid to think of? I'm assuming two-part epoxy is the best way to attach the brackets to the bumper... although, after losing other car parts on I-405 I figure I should double check. |
Rleog |
Jan 20 2021, 04:45 PM
Senior Member Group: Members Posts: 608 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States |
I bolted the brackets on, using the donuts. Then held the bumper in position for test fit. If there is a large gap between bumper and body, the donuts can be shaved.
When I was satisfied with positioning, I mixed a small amount of body filler and covered the ends of the brackets, then pressed the bumper in position until the body filler set. You’re not trying to permanently cement the bumper onto the bracket here, only trying to accurately mark bracket positions on the bumper. Next remove the brackets and bumper and securely fix the brackets to the well marked locations on the bumper with whatever fixation material you choose. Someone else may have a better procedure, but this worked for me. |
Lo-Fi Version | Time is now: 29th May 2024 - 04:58 AM |
