In the rain, Open case |
930cabman |
Jan 24 2021, 02:25 PM
Advanced Member Group: Members Posts: 3,140 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I recently found a 2.0 long block on Ebay, seller said it was laying around for a few years. Heads had been removed previously. Cylinders missing. I am hoping to salvage a case, crank, rods, ...
Removing the pistons required heat prior to driving out the pins. Removing the oil pump was somewhat of a chore, when it finally came out my suspicion was confirmed. Directly behind the pump was filled with white crusty junk. I had suspected during storage it had seen some weather. I have been using a 3/8" x 2" x 12" steel bar with a two pound hammer to separate the halves. It has opened up a few thou, at least now I am hearing a hollow sound when hammering. Question: I am thinking the studs going through the case are corroded? I am sure someone has run into this. thank you, |
warpig |
Jan 24 2021, 08:45 PM
Member Group: Members Posts: 290 Joined: 2-August 10 From: Portland OR Member No.: 12,002 Region Association: Pacific Northwest |
Keep looking for another through bolt. I just did the same thing splitting my case a few weeks ago and thought I had them all. After pounding away and checking six or a hundred times that all the bolts were out, I found the elusive hidden through bolt.
I can't remember exactly where it was and I have only this pic in my phone but, if you look to the center and slightly above the holes where the lifters reside. You may understand what I mean. This may not be the precise spot where the bolt was, but it is down in a dark recess, not around the edge of the case like the others. (my case is across town or I would go get a good pic) It is hidden and covered with old oil and gunk. I was very surprised to find it down there. If you don't know where it is, you have to search. (maybe with a flashlight) Good Luck. |
930cabman |
Jan 25 2021, 08:24 AM
Keep looking for another through bolt. I just did the same thing splitting my case a few weeks ago and thought I had them all. After pounding away and checking six or a hundred times that all the bolts were out, I found the elusive hidden through bolt. I can't remember exactly where it was and I have only this pic in my phone but, if you look to the center and slightly above the holes where the lifters reside. You may understand what I mean. This may not be the precise spot where the bolt was, but it is down in a dark recess, not around the edge of the case like the others. (my case is across town or I would go get a good pic) It is hidden and covered with old oil and gunk. I was very surprised to find it down there. If you don't know where it is, you have to search. (maybe with a flashlight) Good Luck. Thank you, it was hiding under 1/4" of gunk, couldn't make out a bolt at all. She's split now. |
Lo-Fi Version | Time is now: 5th June 2024 - 09:27 AM |
