| BillJ |
Jan 26 2021, 03:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,356 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
When i got my new fuel tank from Dansk it turns out that the rib that runs along the top of the tank is too tall for the mounting strap and guide. This means that when you tighten it down it does a beautiful job of destroying your plastic guide.
Attached thumbnail(s) |
| BillJ |
Jan 26 2021, 03:38 PM
Next, using a cutting wheel in my case, carefully remove about 10mm or so of material off the rib. Just go slow.
Once complete paint the exposed metal to prevent rust. Your car has enough already from the factory (IMG:style_emoticons/default/biggrin.gif) Then reassemble and take care to put the hoses back properly. I marked mine to make sure i did that right. Always use fuel line clamps. This is fuel. Install tank and enjoy a secure fuel tank. Hope this helps people to tackle this easy project. For me the growing amount of junk inside the old tank made this new tank a no brainer compared to hours of cleaning, sealing, and hoping it worked with the old tank. Attached thumbnail(s) |
BillJ DIY: Dansk Fuel Tank Mod Jan 26 2021, 03:20 PM
BillJ A fix is trim off some of the material under the g... Jan 26 2021, 03:26 PM
aturboman Had the same experience with my Dansk tank.
Since... Jan 26 2021, 03:31 PM
BillJ I will say you could probably do this with the tan... Jan 26 2021, 03:45 PM
914Sixer What about gluing some rubber pads on to the plast... Jan 27 2021, 08:08 PM
raynekat
What about gluing some rubber pads on to the plas... Jan 27 2021, 09:53 PM
BillJ Of course if you do this to the tank when you firs... Jan 27 2021, 10:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th October 2026 - 10:35 AM |
