Dual CHT Gauge? |
Dual CHT Gauge? |
BillJ |
Jan 26 2021, 08:02 AM
Senior Member Group: Members Posts: 1,100 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
When I had a track car many years ago it had a dual CHT gauge that was very nice for detecting unequal heating on each bank. Definitely want to add this to my current car once the 2056 goes in. I cannot for the life of me find one that is both Fahrenheit and a good match for the other indicators in cabin. Anyone have one they use and recommend?
BillJ |
Jan 26 2021, 03:04 PM
Thanks for the links. On the engine side of things how do you all install the sensors? Are they different than what is listed for this aircraft application?
VaccaRabite |
Jan 27 2021, 06:59 PM
En Garde! Group: Admin Posts: 13,450 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Thanks for the links. On the engine side of things how do you all install the sensors? Are they different than what is listed for this aircraft application? Thats easy. The sensors all have big ring terminals on them that go under the spark plugs. You remove the washer from the plug, put the sender ring on there, and thread the plugs back in. You may need to grind the heads a little to carve a channel for the wire under the plug to come out of the heads. Pretty easy. Zach |
Mark Henry |
Jan 28 2021, 06:59 AM
Thanks for the links. On the engine side of things how do you all install the sensors? Are they different than what is listed for this aircraft application? Thats easy. The sensors all have big ring terminals on them that go under the spark plugs. You remove the washer from the plug, put the sender ring on there, and thread the plugs back in. You may need to grind the heads a little to carve a channel for the wire under the plug to come out of the heads. Pretty easy. Zach Well not that easy, you often have to R&R the engine to clear the head for the thermocouple and trying to install it without this clearance could ruin the thermocouple. |
Lo-Fi Version | Time is now: 29th May 2024 - 12:08 AM |
