x-faktory T4, 1911 T4 with EFI/ITBs |
x-faktory |
Jan 26 2021, 02:19 PM
Newbie Group: Members Posts: 21 Joined: 16-August 13 From: PNW Member No.: 16,261 Region Association: Pacific Northwest |
Some of you may be aware of my 911 engine builds, but...I've decided on building a T4-1911.....I was quickly going down the rabbit hole with bigger/better, but then reminded myself of one of the primary goals......and that is to help configure the RHD T'body design that I am using on the 911 builds... to be used for the 4 cylinder engines...starting with the Type 4. Parts are arriving and here is a sneak peek at the 1st units, mounted to manifolds.......
Stay tuned as parts for the build are arriving daily regards, al |
Shivers |
Jan 27 2021, 09:05 PM
Senior Member Group: Members Posts: 2,410 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
42mm, big for a 1911, really curious to see how it will run when it's done.
barefoot |
Jan 28 2021, 08:00 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Mark Henry |
Jan 28 2021, 10:26 AM
42mm, big for a 1911, really curious to see how it will run when it's done. For carb's yes, for FI should not matter at all as fuel delivery is independent of throat size. Yes...but...too big and you make vacuum issues worse, add a big duration cam and you're running in alphaN/TPS only. |
JamesM |
Jan 28 2021, 10:48 AM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
42mm, big for a 1911, really curious to see how it will run when it's done. For carb's yes, for FI should not matter at all as fuel delivery is independent of throat size. Yes...but...too big and you make vacuum issues worse, add a big duration cam and you're running in alphaN/TPS only. (IMG:style_emoticons/default/agree.gif) Might as well cam the hell out of it as you are most likely going to have very little resolution with the vacuum signal and have to run alphaN anyways Ran 42mm Jenveys on a 2270 with a cam optimized for lower RPM/very good vacuum and was still seeing 0 vacuum at roughly 30% throttle off idle . They were a pretty good match for that motor, running in MS hybrid mode split the map almost 50/50. Running on a 1911 I wouldn't be surprised if you wind up seeing no vacuum across 70%+ of operating conditions. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:08 PM |
