123 Distributor, W/dual 40 Webbers Timing? suggestions?, Setting up the timing .new 123 tune distributor |
914lasvegas |
Jan 31 2021, 07:45 AM
Newbie Group: Members Posts: 4 Joined: 18-November 20 From: The LasVegas Member No.: 24,903 Region Association: None |
Getting ready to install My new 123 tune distributor with Bluetooth . Not sure where to set the timing for my particular application . Hoping for some suggestions.
Motor is A freshly rebuilt 1.8 from 1974 914 Dual Weber. 40's IDF carburetors. no vac Motor is installed on a 1965 beetle (baja) BIG tires. I don't know if the cam was changed . I do know the motor has new heads on it . But I don't know anything about them. Besides the 123 tune I also bought a new set of wires and a Bosch blue. What should I set the rev limiter at? Any other suggestions regarding my install ? Any advice would be appreciated . I am a green newbee. Thank you .Stewart |
Mark Henry |
Feb 2 2021, 01:32 PM
Whatever gives you 800-900 RPM AT 8 degrees (7.5) BTDC and full advance 3000 rpm 28 degrees BTDC. So really it only gives you 20 degrees of mechanical advance.
I wouldn't exceed 28 degrees of total advance, but I'd play with any curve that stays within these parameters. |
914lasvegas |
Feb 7 2021, 11:59 AM
Lo-Fi Version | Time is now: 2nd June 2024 - 03:18 AM |
