| bbrock |
Feb 8 2021, 07:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
I know this is a futile quest since most of you think it is only civilized to convert the pneumatic windshield washer to an electric pump. But c'mon, that has to be the most ridiculously quirky quirk of a car dripping with quirkiness. Anything that stupid has to be worth keeping... right?
But I have a problem. The seal inside the fitting that screws onto the spare tire was shot and leaking all the air out of the tire. That wasn't going to work so I dug it out and and replaced it with a stack of neoprene washers that looked to be the right size and sealed to each other with a smear of RTV. It worked... almost. It seals tight unless you bend the hose to the side at all and then it leaks. Of course, mounting the tire in the frunk with the hose on bends it to the side. So what to do? Anyone have suggestions on how to seal this thing, or where a replacement might be found? New hoses with fittings are NLA and the ransom demanded by folks with used ones seems steep considering they might very well leak also. Thoughts? (IMG:style_emoticons/default/confused24.gif) |
| windforfun |
Feb 9 2021, 07:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,114 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
Move to California & the issue becomes rather mute. Mine leaks, but I never need to use it.
(IMG:style_emoticons/default/smile.gif) |
| bbrock |
Feb 9 2021, 07:56 PM
Move to California & the issue becomes rather mute. Mine leaks, but I never need to use it. (IMG:style_emoticons/default/smile.gif) Yes, but then I'd be stuck living in California (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/smile.gif) |
bbrock Washer hose spare tire fitting Feb 8 2021, 07:40 PM
Jamie
I know this is a futile quest since most of you t... Feb 8 2021, 08:53 PM
Jett
I know this is a futile quest since most of you t... Feb 8 2021, 09:27 PM
Montreal914 Anything that could be borrowed from the VW Beetle... Feb 8 2021, 10:15 PM
bbrock I do have the 914Rubber hose kit installed and eve... Feb 8 2021, 10:42 PM
bbrock Hmm. I wonder if that hose would stretch over a 1... Feb 8 2021, 10:51 PM
Mikey914
Hmm. I wonder if that hose would stretch over a ... Feb 9 2021, 10:51 AM
wonkipop
I know this is a futile quest since most of you t... Feb 8 2021, 11:03 PM
wonkipop i have found this - i might chase up myself.
from... Feb 9 2021, 09:22 AM
DRPHIL914
fro... Feb 9 2021, 10:06 AM
wonkipop
[quote name='wonkipop' post='2889685' date='Feb 9... Feb 9 2021, 10:39 AM
bbrock
[quote name='DRPHIL914' post='2889699' date='Feb ... Feb 9 2021, 04:21 PM
wonkipop @ bbrock.
pardon the limey spelling rather than m... Feb 9 2021, 05:56 PM
bbrock
there is something going on there because that h... Feb 9 2021, 06:58 PM
wonkipop thats a hot tip for how to get the hose replacemen... Feb 9 2021, 07:05 PM
bbrock
---- when thanks to you after 30 odd years of ow... Feb 9 2021, 07:32 PM
ClayPerrine
its actually a bit of a hassle in the 914 as i a... Feb 25 2021, 09:03 AM
914sgofast2
Move to California & the issue becomes rathe... Feb 9 2021, 09:12 PM
preach Brent I am pretty sure I have a '72 one and a ... Feb 9 2021, 09:20 PM
wonkipop australia has become california on very bad drugs.... Feb 10 2021, 12:36 AM
Mikey914 Just a heads up on the tubing we make. you MUST pu... Feb 10 2021, 01:08 PM
Superhawk996 I admire the perseverance . . . :screwy:
:... Feb 10 2021, 02:41 PM
bbrock
... Feb 24 2021, 11:31 AM
wonkipop
... Feb 25 2021, 02:35 PM
wonkipop :screwy: goes without saying.
cracked the proble... Feb 13 2021, 05:11 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th August 2026 - 06:19 AM |
