MartyYeoman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California ![]() ![]() |
Kinda says it all.
Any available somewhere? Item #30 in the attachment. Attached image(s) ![]() |
Fosterjoejr |
Newbie ![]() Group: Members Posts: 1 Joined: 30-December 15 From: Dallas Texas Member No.: 19,502 Region Association: Southwest Region ![]() ![]() |
Kinda says it all. Any available somewhere? Item #30 in the attachment. 914 Rubber has this. https://914rubber.com/search/?q=grommet%20B021119553 |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,542 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Kinda says it all. Any available somewhere? Item #30 in the attachment. 914 Rubber has this. https://914rubber.com/search/?q=grommet%20B021119553 They do not show a part that matches that part number. Your search looks for all grommets. The only one that looks close is this which is described as 24mm rubber sleeve. the CHT hole is 26mm. Attached thumbnail(s) ![]() |
bdstone914 |
Kinda says it all. Any available somewhere? Item #30 in the attachment. 914 Rubber has this. https://914rubber.com/search/?q=grommet%20B021119553 Your search looks for all grommets. The only one that looks close is this which is described as 24mm rubber sleeve. the CHT hole is 26mm. Edit. I had an OEM Porsche gromett that had the same referance number as the 914 Rubber part. It fits in the hole with some slop but looks like it is will work ok. |
Lo-Fi Version | Time is now: 17th June 2024 - 04:46 AM |
