Hard to get 1st gear on side shift conversion chassis, shift rod hitting on the original bushing support in tunnel |
PlaysWithCars |
Feb 6 2021, 10:56 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Wondering if anyone else has had this issue. This has been a multi-year saga and now I've kind of been all the way around the barn and only made small improvements but I think I've narrowed it down to the final culprit.
Backstory: 1970 914-6 chassis that has a side shift transmission in it that has always been tough to get into first gear. It feels like it just barely gets into gear but once there its never popped out. When the car was new to me, I didn't have history on the transmission and assumed it was just worn or the shift bushings were worn so I put it on the to-do list to rebuild it someday. In the meantime I invested in a Rennshift shifter and installed it with new bushings at the shift console on the transmission (all other bushings seemed fairly tight). Improved shifting overall, but no real change to the issue with 1st gear. Fast forward and I bought another transmission to rebuild with the help of the Doc's DVD. Tore down the transmission, rebuilt with a mix of new and used parts expecting the problem would be solved. To my disappointment, no real change in the behavior when I put the rebuilt transmission in. Mind you though, I'm thrilled with other aspects of the rebuild: new gearing (A, F, Ka, S, ZA is a nice combo for autocross / street use), Guard limited slip helped keep the car connected at corner exit. Now this is where I began scratching my head. This is a completely different transmission with no shared parts from the old unit. How can I have the same problem? Clearly its something on the chassis not in the transmission. So, I started looking real close at all of the bushings in the linkage. As I said each was pretty tight but each had some small amount of play so I started replacing each one with small, incremental improvements made each time. And each time I went through the process of adjusting the shift linkage but still wasn't getting first to work much better. All the other gears? No problem. But first was not cooperative. Getting ready for the autocross season this year, I decided to try and tackle it again. I'm tired of pulling up to the start line and fighting to get into first. And last season my 16 yr old son started racing it with me. It was heartbreaking to see how it added so much anxiety in him trying to get into first gear so as not to delay the start of his run. So, I went through it all again. Checked bushings, adjusted the shifter and still could not get it better until I decided to adjust the shifter focusing only on the R-1 shifter plane. When I did that? First was like butter, but I couldn't get into the 4-5 shift plane at all. After some more head scratching and investigation I snaked a bore scope down into the tunnel and found what I think has been my problem all along. When moving the shifter left / right into the R-1 and 4-5 shift planes the shift rod is hard up against the support that would have held the bushing for the original side shift linkage (item #14 below). I haven't read of anyone having this issue when a car's been converted to a side shift. Is this a know issue? Is there a common cause / solution to gain clearance in this area? For now, I readjusted the linkage so that I minimize the interference in the R-1 and 4-5 planes but it is negatively impacting shifting in all but 2-3 gears until I can figure out a solution. |
davehg |
Feb 11 2021, 01:21 AM
Member Group: Members Posts: 185 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
I had my transmission rebuilt recently after noting a similar problem. My restoration shop used Tangerine Racing’s shift rod kit and their precision shift adjuster, and it cured most of the sloppiness in shifting. The adjuster may help you fine tune the shifter. Already had the shift rod bearing.
http://www.tangerineracing.com/transmission.htm At a stop I still sometimes have challenges shifting into first, but I first put it in second, then into first and it works. I have a 3.2 mated to my 901 so I generallly avoid using first except in a parking lot. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:05 PM |
