| enf2232 |
Feb 15 2021, 08:35 AM
Member ![]() ![]() Group: Members Posts: 89 Joined: 13-July 14 From: Toledo, OH Member No.: 17,621 Region Association: None |
Anyone ever consider an aircraft engine swap? Saw the Youtube video and it made me wonder.
https://www.youtube.com/watch?v=6jMoXiQ11Bk |
| Unobtanium-inc |
Feb 16 2021, 10:08 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None
I've seen it the other way around, 914 motor in a gyro-copter.
| bdstone914 |
Feb 16 2021, 11:17 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
| mb911 |
Feb 16 2021, 11:39 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,730 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I've seen it the other way around, 914 motor in a gyro-copter. Does not look like a well planned design with no shrouding around the heads, cylinder or oil cooler. Its a free air design which is very common in aircraft applications with no cowls. It is also cooler as you climb so that helps. Its the fast decents though that causes issues as it super cools the cylinders and shrinks them to the pistons. Btdt when living in that world. I rebuilt a few hundred engines while in the business. |
| ClayPerrine |
Feb 16 2021, 12:22 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I've seen it the other way around, 914 motor in a gyro-copter. Does not look like a well planned design with no shrouding around the heads, cylinder or oil cooler. Its a free air design which is very common in aircraft applications with no cowls. It is also cooler as you climb so that helps. Its the fast decents though that causes issues as it super cools the cylinders and shrinks them to the pistons. Btdt when living in that world. I rebuilt a few hundred engines while in the business. I already said this in the original thread, I would not do that. The thrust surfaces in that engine are not designed for use with a propeller. It would tear them up rapidly. Aircraft engines have huge thrust bearings to take the load of the propeller pulling on them. The cases are much beefier, and they have dedicated mounts for the load. If you want to run an automotive engine, use a drive that both lowers the prop speed and transfers the load of the propeller to a strong bearing surface. |
enf2232 Aircraft engine Feb 15 2021, 08:35 AM
76-914
Anyone ever consider an aircraft engine swap? Sa... Feb 15 2021, 09:02 AM
Shivers Tucker used a H-6 intended for a bell helicopter. ... Feb 15 2021, 09:50 AM
bdstone914 Why? What do you see and possible advantages ?
An... Feb 15 2021, 10:03 AM
Mark Henry It's like the flying car or the amphibious car... Feb 15 2021, 10:05 AM
ConeDodger
It's like the flying car or the amphibious ca... Feb 16 2021, 04:21 PM
Unobtanium-inc
It's like the flying car or the amphibious ca... Feb 16 2021, 08:29 PM
Amphicar770
It's like the flying car or the amphibious ca... Feb 17 2021, 05:31 PM
9146GUY Been there done that.......
https://www.autoevolu... Feb 15 2021, 10:05 AM
mb911 Spent my former life rebuilding aircraft engines. ... Feb 15 2021, 11:08 AM
maj75 There are probably hundreds of aircraft with VW ai... Feb 15 2021, 11:37 AM
oakdalecurtis See this post about putting a Merlin engine in a 9... Feb 15 2021, 12:40 PM
See this post about putting a Merlin engine in a ... Feb 15 2021, 04:02 PM
mbseto It would be amusing to see a car - any car - with ... Feb 15 2021, 03:55 PM
It would be amusing to see a car - any car - with... Feb 15 2021, 04:01 PM
gereed75 The standard four cylinder Lycoming is 360 cubic i... Feb 15 2021, 04:23 PM
Mueller
The standard four cylinder Lycoming is 360 cubic ... Feb 15 2021, 05:01 PM
PanelBilly I see O’Reilys has Flux Capacitors on their webs... Feb 15 2021, 05:33 PM
Shivers Well, this is how it can happen. At least someone ... Feb 15 2021, 06:19 PM
Mikey914 For what you would pay for a serviceable aircraft ... Feb 16 2021, 03:47 AM
dhuckabay My plane has a Continental 360ci, supercharged. R... Feb 16 2021, 04:21 AM
dhuckabay My plane has a Continental 360ci, supercharged. R... Feb 16 2021, 04:22 AM
Unobtanium-inc
I've seen it the other way around, 914 motor... Feb 16 2021, 11:21 AM
bdstone914
[quote name='bdstone914' post='2891821' date='Feb... Feb 17 2021, 11:47 AM
mb911
[quote name='bdstone914' post='2891821' date='Fe... Feb 16 2021, 02:08 PM
ClayPerrine
I already said this in the original thread, I w... Feb 16 2021, 03:31 PM
Superhawk996
I use to travel to EAA events and give presentat... Feb 17 2021, 12:13 PM
76-914
[quote name='ClayPerrine' post='2891833' date='Fe... Feb 17 2021, 02:23 PM
Shivers Darwin's gyro award winner. Gaads Feb 16 2021, 11:23 AM
GregAmy That thing is somebody's backyard hack, I doub... Feb 16 2021, 12:22 PM
jd74914
That thing is somebody's backyard hack, I dou... Feb 16 2021, 01:35 PM
GregAmy
IDK, pretty sure that is 356-derived Greg. I saw ... Feb 16 2021, 02:01 PM
jd74914
IDK, pretty sure that is 356-derived Greg. I saw... Feb 16 2021, 03:20 PM
gandalf_025 I’ve seen people use Corvair power in experiment... Feb 16 2021, 01:48 PM
Unobtanium-inc People have been trying to make a Porsche Gyro wor... Feb 17 2021, 09:13 AM
burton73 https://www.roadandtrack.com/car-culture/tr...into... Feb 17 2021, 01:13 PM
Unobtanium-inc
https://www.roadandtrack.com/car-culture/tr...int... Feb 17 2021, 01:44 PM
GregAmy
I think the stock Mooney outperformed the Porsche... Feb 17 2021, 04:33 PM
ClayPerrine I would love to find a PFM setup complete from the... Feb 17 2021, 04:59 PM
Unobtanium-inc
I would love to find a PFM setup complete from th... Feb 17 2021, 05:06 PM
ClayPerrine
I would love to find a PFM setup complete from t... Feb 18 2021, 12:01 PM
GregAmy
I would love to find a PFM setup complete from th... Feb 18 2021, 01:17 PM
ClayPerrine
I would love to find a PFM setup complete from t... Feb 18 2021, 01:20 PM
GregAmy You can decertify an aircraft to put the PFM in it... Feb 18 2021, 01:45 PM
jd74914
I would love to find a PFM setup complete from t... Feb 18 2021, 01:55 PM
GregAmy
Did SM actually close-I thought they merged with ... Feb 18 2021, 02:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:30 PM |
