| 9ONE4_JIM |
Feb 22 2021, 07:30 PM
Newbie ![]() Group: Members Posts: 4 Joined: 18-February 21 From: Solvang, CA Member No.: 25,221 Region Association: Central California |
Hi Members. Apologies for my very first post being a Porsche "Newbie" one, but I had a bear of a time yesterday trying to remove the oil filter on my just-acquired '73 914 2.0.
My trusty clamp style removal tool wouldn't expand wide enough to grab the old, in-place filter.The OD of original filter case is about 4" (101.6 mm) Side handle tools just would not fit in the limited space as well. After a good hour I did manage to finally get it out! I did the oil sump/strainer clean-up and regasketing as well – which also required some patience and coaxing. So my question is, is there a recommended wrench, socket or clamp tool for the oil filter removal? Thanks in-advance for your help. Jim |
| ndfrigi |
Feb 22 2021, 07:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,993 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
no special tool and does not need to tight. Especially for the strainer bolt, don’t over tighten it or else you will end up opening the engine case.
9ONE4_JIM Oil Filter Removal Tool Feb 22 2021, 07:30 PM
ClayPerrine I just use a pair of humongous channel locks.
:e... Feb 22 2021, 07:52 PM
JeffBowlsby
:... Feb 22 2021, 10:22 PM
Mark Henry
... Feb 23 2021, 06:42 AM
914 RZ-1
Hi Members. Apologies for my very first post bein... Feb 22 2021, 09:26 PM
914_7T3 I thought it was hand tighten and remove as same.
... Feb 22 2021, 10:17 PM
JamesM
I thought it was hand tighten and remove as same.... Feb 24 2021, 02:40 PM
iankarr I like these...one tool, many cars...
https://www... Feb 22 2021, 10:32 PM
jd74914
https://ww... Feb 24 2021, 12:19 PM
roblav1 You can always hammer a screwdriver right through ... Feb 23 2021, 12:23 PM
Mark Henry
You can always hammer a screwdriver right through... Feb 24 2021, 10:56 AM
9ONE4_JIM Thanks for all the suggestions and specific ideas ... Feb 24 2021, 12:14 PM
ClayPerrine
And thanks for the idea of a simply using a humo... Feb 24 2021, 02:07 PM
914forme I have used this one since the 80s, works on 99% o... Feb 24 2021, 02:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 09:59 PM |
