| 9ONE4_JIM |
Feb 22 2021, 07:30 PM
Newbie ![]() Group: Members Posts: 4 Joined: 18-February 21 From: Solvang, CA Member No.: 25,221 Region Association: Central California |
Hi Members. Apologies for my very first post being a Porsche "Newbie" one, but I had a bear of a time yesterday trying to remove the oil filter on my just-acquired '73 914 2.0.
My trusty clamp style removal tool wouldn't expand wide enough to grab the old, in-place filter.The OD of original filter case is about 4" (101.6 mm) Side handle tools just would not fit in the limited space as well. After a good hour I did manage to finally get it out! I did the oil sump/strainer clean-up and regasketing as well – which also required some patience and coaxing. So my question is, is there a recommended wrench, socket or clamp tool for the oil filter removal? Thanks in-advance for your help. Jim |
| roblav1 |
Feb 23 2021, 12:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
You can always hammer a screwdriver right through the thing and twist. Makes nice puddles on the pavement and turns shirts into new rags!
| Mark Henry |
Feb 24 2021, 10:56 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
9ONE4_JIM Oil Filter Removal Tool Feb 22 2021, 07:30 PM
ndfrigi no special tool and does not need to tight. Espec... Feb 22 2021, 07:34 PM
ClayPerrine I just use a pair of humongous channel locks.
:e... Feb 22 2021, 07:52 PM
JeffBowlsby
:... Feb 22 2021, 10:22 PM
Mark Henry
... Feb 23 2021, 06:42 AM
914 RZ-1
Hi Members. Apologies for my very first post bein... Feb 22 2021, 09:26 PM
914_7T3 I thought it was hand tighten and remove as same.
... Feb 22 2021, 10:17 PM
JamesM
I thought it was hand tighten and remove as same.... Feb 24 2021, 02:40 PM
iankarr I like these...one tool, many cars...
https://www... Feb 22 2021, 10:32 PM
jd74914
https://ww... Feb 24 2021, 12:19 PM
9ONE4_JIM Thanks for all the suggestions and specific ideas ... Feb 24 2021, 12:14 PM
ClayPerrine
And thanks for the idea of a simply using a humo... Feb 24 2021, 02:07 PM
914forme I have used this one since the 80s, works on 99% o... Feb 24 2021, 02:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 10:00 PM |
