Improving dash light brightness? |
Cuda911 |
Aug 22 2014, 12:21 AM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Hey all,
My one (and only) complaint with my 914 is that the dash lights are very faint and very hard to see at night (speedometer, etc.). Someone told me that brighter LED bulbs are available. Is that correct? If so, can someone provide me with: 1. What bulbs? 2. What source to buy them? 3. How many do I need? 4. Are they direct replacements (i.e. no other modifications need to install them) 5. To replace them, do I take out the 5 or so screws on the dash faceplate to access them? Thanks, guys! |
barefoot |
Oct 5 2020, 09:31 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
4 different bulb holders, 2 bulb styles & new LED options:
Left to right: spade remote ground, spade case ground, bayonet remote ground, bayonet case ground New LED lamp for spade holder, 3 OEM bulbs My Hi beam indicator lamp was barely visible even at night, now with new LED lamp, visible in daylight. Same lamp used in combo gage for backlighting, now brighter (IMG:style_emoticons/default/smile.gif) Purchased from Amazon Prior post shows LED lamps for the larger bayonet mount, which i hadn't seen before my quest for brighter lighting. Also got new LED lamps for Rear tail light outer most positions, same size fits rear trunk housing. |
drem914 |
Feb 27 2021, 03:10 PM
Senior Member Group: Members Posts: 1,032 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
4 different bulb holders, 2 bulb styles & new LED options: Left to right: spade remote ground, spade case ground, bayonet remote ground, bayonet case ground New LED lamp for spade holder, 3 OEM bulbs My Hi beam indicator lamp was barely visible even at night, now with new LED lamp, visible in daylight. Same lamp used in combo gage for backlighting, now brighter (IMG:style_emoticons/default/smile.gif) Purchased from Amazon Prior post shows LED lamps for the larger bayonet mount, which i hadn't seen before my quest for brighter lighting. Do you have a listing for the colored spade bulbs you bought off Amazon? Were the ba7 lts. 2 watt LEDs? I have already swapped my bulbs previously for the single chip LEDs before they made the more powerful ones so I wanted to change the colored lts at the same time. Thanks for any info you can provide. |
Lo-Fi Version | Time is now: 3rd June 2024 - 02:43 AM |
