Where to buy bolts, Does it matter where you buy them |
Dredwin |
Mar 1 2021, 11:51 AM
Member Group: Members Posts: 71 Joined: 21-December 13 From: Colorado Springs Member No.: 16,783 Region Association: Rocky Mountains |
I am needing to replace some CV bolts for a larger axle. They are M8 with 1.25 thread (12.9) and 56MM top to bottom. Are bolts relatively the same if they are the right size and strength? Suggestions on where to buy?
Mark Henry |
Mar 1 2021, 01:22 PM
I am needing to replace some CV bolts for a larger axle. They are M8 with 1.25 thread (12.9) and 56MM top to bottom. Are bolts relatively the same if they are the right size and strength? Suggestions on where to buy? Could you elaborate on the above point in bold. Bolts are measured not counting the head. 56mm sounds right, but did you measure correctly? You also need new schnorr washers (my spelling may be off). VW aircooled shops also have these bolts. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:49 PM |
