mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Because I don't have enough going on right now, I bought a 912 project. (IMG:style_emoticons/default/headbang.gif)
Attached image(s) ![]() ![]() ![]() |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,906 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
I’d build it with the OEM engine. Who cares if it’s not fast. It cool!
mepstein |
I’d build it with the OEM engine. Who cares if it’s not fast. It cool! I agree. Once it's up and running I might try building in lightness. Remove parts, put them aside and replace with lighter pieces. Between bumpers, engine lid, seats, wheels and some other parts, I think 150-200lbs is possible. A lexan rear window only saves 15lbs but its high and far back enough that it might help. Fiberglass light buckets are a lot lighter than oem. A lightweight exhaust is the perfect spot to save weight. So there's still plenty of opportunity to let the sickness take hold. The current owner checked with fat and was told it should be a 115-120hp engine so that would be similar to an early 911 but 200lbs less. |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,587 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
I’d build it with the OEM engine. Who cares if it’s not fast. It cool! I agree. Once it's up and running I might try building in lightness. Remove parts, put them aside and replace with lighter pieces. Between bumpers, engine lid, seats, wheels and some other parts, I think 150-200lbs is possible. A lexan rear window only saves 15lbs but its high and far back enough that it might help. Fiberglass light buckets are a lot lighter than oem. A lightweight exhaust is the perfect spot to save weight. So there's still plenty of opportunity to let the sickness take hold. The current owner checked with fat and was told it should be a 115-120hp engine so that would be similar to an early 911 but 200lbs less. Nice, 15-120 in a 912 would be a blast. I have probably 100 in my 356 due to the 1772cc setup and it's good enough to keep up with traffic. |
Lo-Fi Version | Time is now: 16th July 2025 - 04:01 PM |
