What do I need to worry about when replacing all gaskets/seals in my transmission?, I don't want to do the transmission equivalent of letting out the magic smoke |
messick |
Mar 11 2021, 01:53 PM
Newbie Group: Members Posts: 39 Joined: 15-June 20 From: Orange, CA Member No.: 24,381 Region Association: Southern California |
I've taken the engine/trans out of my car in my "get this six conversion back on the road after sitting for almost 20 years" quest, and since I'm in there, I'm replacing all the seals and whatnot that have obvious leakage issues going on.
Engine wise is pretty straight forward what's easy to do, and what requires something like splitting the case, so not too worried there. However, for the transmission, I'm not sure what I can do without making myself miserable. I have the Erling gasket kit. And while the speedo, shift, input, and drive seals seem obvious, can I just take the case apart to replace the larger gaskets? The last thing I want to do is take everything apart to find out I need some sort of adjustment rig if I ever want it to go back together and shift correctly I tried to find a writeup from someone either here or from the bird site that laid out all the steps, but I couldn't find anything about doing all the gaskets/seals in the kit. So if anyone has a link to one of those, that would be great. Thanks all. |
brant |
Mar 11 2021, 02:46 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
you would be better off not to open the tranny
at least as far as the intermediate plate/gasket I'd leave it alone unless you want to rebuild the inside as mentioned, that gasket sets the ring and pinion differential it MUST be the same as the original setting or will require a very special tool I'd replace the front output, side outputs, etc.. and not open the box you can take just the rear cover off and regasket that one, if you want... the 2nd plate is the intermediate |
messick |
Mar 11 2021, 05:43 PM
you would be better off not to open the tranny at least as far as the intermediate plate/gasket I'd leave it alone unless you want to rebuild the inside as mentioned, that gasket sets the ring and pinion differential it MUST be the same as the original setting or will require a very special tool I'd replace the front output, side outputs, etc.. and not open the box you can take just the rear cover off and regasket that one, if you want... the 2nd plate is the intermediate Sounds good, I definitely do not want to do a rebuild at this time. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:15 PM |
