Momo steering wheel swap, Need help |
Morph914 |
Mar 16 2021, 05:53 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I thought I had all the parts for this swap but now I’m not sure. First off when I mocked the parts up I noticed my contact ring is toast.
I also went with the J West adapter to bring the wheel out and up a bit. I know the wire from the contact ring goes up through the hub and connects to the center tab on the horn button, and I thought the other tab on the horn button grounded to the silver ring that sits under the wheel. But after putting this together I’m not sure . And after putting the horn button in the wheel, it does not seat properly. What holds the horn button in anyway? Also, is the blinker canceling tab mounted at the 3 o clock position if the wheel is straight? Attached thumbnail(s) |
Steve |
Mar 17 2021, 10:21 AM
914 Guru Group: Members Posts: 5,614 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I had the same problem with the same parts. The tab is at 3 o'clock . On the horn button, one wire goes to the ground, which is the connection on the silver ring and the other wire goes to the horn ring.
In my stash of spare parts and wheels, I had a black ring, that holds the horn button in place. I don't know if you can buy this ring separately. There might also be a horn button that works without the ring. You will also need longer screws. |
Lo-Fi Version | Time is now: 11th June 2024 - 06:04 AM |
