I thought I had all the parts for this swap but now I’m not sure. First off when I mocked the parts up I noticed my contact ring is toast.
I also went with the J West adapter to bring the wheel out and up a bit.
I know the wire from the contact ring goes up through the hub and connects to the center tab on the horn button, and I thought the other tab on the horn button grounded to the silver ring that sits under the wheel. But after putting this together I’m not sure
.Click to view attachment
And after putting the horn button in the wheel, it does not seat properly. What holds the horn button in anyway?
Also, is the blinker canceling tab mounted at the 3 o clock position if the wheel is straight?
