Momo steering wheel swap, Need help |
Morph914 |
Mar 16 2021, 05:53 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I thought I had all the parts for this swap but now I’m not sure. First off when I mocked the parts up I noticed my contact ring is toast.
I also went with the J West adapter to bring the wheel out and up a bit. I know the wire from the contact ring goes up through the hub and connects to the center tab on the horn button, and I thought the other tab on the horn button grounded to the silver ring that sits under the wheel. But after putting this together I’m not sure . And after putting the horn button in the wheel, it does not seat properly. What holds the horn button in anyway? Also, is the blinker canceling tab mounted at the 3 o clock position if the wheel is straight? Attached thumbnail(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 02:41 PM |
