Morph914 |
Member ![]() ![]() Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States ![]() ![]() |
I thought I had all the parts for this swap but now I’m not sure. First off when I mocked the parts up I noticed my contact ring is toast.
![]() I also went with the J West adapter to bring the wheel out and up a bit. ![]() I know the wire from the contact ring goes up through the hub and connects to the center tab on the horn button, and I thought the other tab on the horn button grounded to the silver ring that sits under the wheel. But after putting this together I’m not sure . ![]() And after putting the horn button in the wheel, it does not seat properly. What holds the horn button in anyway? ![]() Also, is the blinker canceling tab mounted at the 3 o clock position if the wheel is straight? Attached thumbnail(s) ![]() |
DC_neun_vierzehn |
Member ![]() ![]() Group: Members Posts: 399 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region ![]() ![]() |
This is good info as I'm hoping to add a Momo Prototipo wheel one day to my 914 as well. Please let us know if you get it working and what was the solution (parts and #s).
What size Momo wheels fit best on our 914s? Does the 350mm wheel work best? |
Lo-Fi Version | Time is now: 10th June 2024 - 04:59 PM |
