| timothy_nd28 |
Mar 1 2021, 04:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
Group Buy ending in less than 1 week!
I have heard nothing but great things about this aftermarket distributor. I won't be part or this group buy, because I already purchased one a few weeks ago for my Ljet. While speaking with Ed at 123ignition, I told him that it might be good time to set up a group buy for the month of March, to help get our 914's running better for summer driving (IMG:style_emoticons/default/driving.gif) Ed told me: 1-5 people will get 5% off. 6-10 people, would be 10% off. 11+ people, is 10% off and free shipping within the US. Pretty sure Ed said that if we get 1000 people, he would fly out to each of our houses and personally install the new dizzy himself! (kidding) Group Buy 3/1/2021 thru 3/31/2021 Coupon code: 914world21 Please order using this site: 123ignitionusa.com I borrowed some links from the last group buy (thanks Rob)! Ed mentioned that the Djet version dizzy still does not have the bluetooth function. * Newest bluetooth model for D-jet 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. This group buy will also apply for other engines such as the 911 six cylinders. ![]() https://www.youtube.com/watch?v=3wZ2xj6SAfI |
| CMONNETT |
Mar 19 2021, 10:08 AM
Member ![]() ![]() Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region |
Has anyone else had a problem with these 123's cutting out? I bought one for D-Jet on the first group buy to install when I finished my 2056 build. The thing didn't even last 1000mi. I finally just put the stock dizzy back in, and the car hasn't given me an issue since.
Thanks, Chris |
| rjames |
Mar 19 2021, 11:35 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,418 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Has anyone else had a problem with these 123's cutting out? I bought one for D-Jet on the first group buy to install when I finished my 2056 build. The thing didn't even last 1000mi. I finally just put the stock dizzy back in, and the car hasn't given me an issue since. Thanks, Chris What were the symptoms, or did it just completely stop working one day? |
| CMONNETT |
Mar 19 2021, 03:00 PM
Has anyone else had a problem with these 123's cutting out? I bought one for D-Jet on the first group buy to install when I finished my 2056 build. The thing didn't even last 1000mi. I finally just put the stock dizzy back in, and the car hasn't given me an issue since. Thanks, Chris What were the symptoms, or did it just completely stop working one day? At first it started with a real faint stumble, then the car would just start bucking real bad and finally died on the hwy. Had it towed home, and the thing fired up like nothing once it got off the truck. It was the first time I have ever had to tow the car in the 20yrs of ownership. It drove fine for a few days and started acting up again, swapped out the dizzy on the side of the road, and it's been fine since. I would send it back, but was told it's only a one year warranty. |
| 123ignitionusa |
Mar 19 2021, 03:18 PM
Member ![]() ![]() Group: Members Posts: 63 Joined: 22-January 16 From: Ohio Member No.: 19,587 Region Association: North East States |
Has anyone else had a problem with these 123's cutting out? I bought one for D-Jet on the first group buy to install when I finished my 2056 build. The thing didn't even last 1000mi. I finally just put the stock dizzy back in, and the car hasn't given me an issue since. Thanks, Chris What were the symptoms, or did it just completely stop working one day? At first it started with a real faint stumble, then the car would just start bucking real bad and finally died on the hwy. Had it towed home, and the thing fired up like nothing once it got off the truck. It was the first time I have ever had to tow the car in the 20yrs of ownership. It drove fine for a few days and started acting up again, swapped out the dizzy on the side of the road, and it's been fine since. I would send it back, but was told it's only a one year warranty. If you want to send it in to me I can check it out. Let you know what is wrong and give you an estimate to fix. Hope this helps Ed |
timothy_nd28 GB 123ignition Mar 1 2021, 04:10 PM
burlybryan Great job setting this up. Been planning on upgra... Mar 1 2021, 06:12 PM
Morph914 Rats!!! I just purchased one last mont... Mar 1 2021, 06:19 PM
warpig
Rats!!! I just purchased one last mon... Mar 19 2021, 09:49 PM
mb911 I bought this setup last year for my -6 and hope t... Mar 1 2021, 06:22 PM
VaccaRabite I have set these up on a 914 before. Its easy and... Mar 1 2021, 06:47 PM
BillC @timothy_nd28
Thank you very much for setting th... Mar 1 2021, 07:20 PM
123ignitionusa
[b]@[url=http://www.914world.com/bbs2/index.php?s... Mar 1 2021, 08:42 PM
Morrie
Unlike the last GB, for this one, orders will be... Mar 19 2021, 02:59 PM
Sycolyst Perfect timing...I'm in. I was planning to pu... Mar 1 2021, 08:02 PM
timothy_nd28 Great question, I'm somewhat fuzzy on how Ed w... Mar 1 2021, 08:13 PM
Robarabian I have one for my 4 and one for the pending 6. Any... Mar 2 2021, 09:23 AM
timothy_nd28
I have one for my 4 and one for the pending 6. An... Mar 2 2021, 04:44 PM
Rand We have been through this. I think it's pretty... Mar 2 2021, 08:08 PM
72914wrx I’m in ! Mar 2 2021, 10:32 PM
Highland Just wondering if the 123 ignition might help with... Mar 7 2021, 05:04 PM
StratPlayer I will be selling my 123 dizzy for a DJet soon. I... Mar 7 2021, 08:37 PM
mate914 What happens if you have the bluetooth+ and you us... Mar 8 2021, 08:08 AM
123ignitionusa
What happens if you have the bluetooth+ and you u... Mar 8 2021, 12:16 PM
timothy_nd28 :bump:
Another two weeks left in this group buy, ... Mar 15 2021, 08:22 PM
123ignitionusa Don't forget to use coupon code 914world21 Mar 16 2021, 05:20 PM
tyfighter123 Just ordered one. Thanks Mar 16 2021, 10:23 PM
123ignitionusa New release - Programmable Bluetooth with D-Jet ou... Mar 17 2021, 10:45 AM
DTMLGND
[size=6]New release - Programmable Bluetooth with... Mar 31 2021, 08:01 PM
orthobiz One time I looked and saw two detailed YouTube vid... Mar 17 2021, 10:48 AM
dax1969
One time I looked and saw two detailed YouTube vi... Mar 19 2021, 03:29 AM
123ignitionusa Click this link Instructional Videos
or click her... Mar 21 2021, 12:50 PM
timothy_nd28 :agree: I concluded that most 914 people are cam... Mar 17 2021, 11:00 AM
timothy_nd28 Updated post one to include the new Djet bluetooth... Mar 17 2021, 12:43 PM
pete000 I installed a blue tooth version in my 74 1.8 L-Je... Mar 17 2021, 05:00 PM
timothy_nd28 I bought the bluetooth version for my Ljet, and wi... Mar 17 2021, 06:20 PM
dax1969 Damn...just bought a 123 ignition for my 74 2.0 dj... Mar 19 2021, 03:35 AM
jhynesrockmtn I'm contemplating two of these. I have a stoc... Mar 19 2021, 08:03 AM
VaccaRabite
Has anyone else had a problem with these 123... Mar 19 2021, 10:33 AM
CMONNETT
[quote name='rjames' post='2900902' date='Mar 19... Mar 19 2021, 03:48 PM
123ignitionusa Hey Guys we are at 5. From here forward 10% discou... Mar 19 2021, 03:14 PM
DRPHIL914 what would be the advantage of having the blue too... Mar 21 2021, 08:02 AM
75914-L20C I just ordered a bluetooth unit for my '75 L-j... Mar 21 2021, 12:47 PM
pete000 Just ordered mine. Thanks for setting this up! Mar 21 2021, 07:11 PM
burlybryan Order placed for D-Jet with BT Mar 24 2021, 08:18 AM
BillJ oh man -JUST finished my 2056 and have the 123 non... Mar 24 2021, 08:45 AM
pstank Ordered L-Jet option! Super excited for this ... Mar 24 2021, 08:52 AM
timothy_nd28 One Week Left!
And we definitely hit the quo... Mar 24 2021, 09:54 AM
Morrie
[size=4][b]One Week Left!
And we definitely... Mar 24 2021, 10:59 AM
Samuelrocky Just ordered today 3-24-21. Mar 24 2021, 12:55 PM
123ignitionusa Thanks for your patronage. Orders are now at 11.
... Mar 24 2021, 02:33 PM
TJB/914
Thanks for your patronage. Orders are now at 11. ... Mar 24 2021, 04:28 PM
123ignitionusa
Thanks for your patronage. Orders are now at 11.... Mar 27 2021, 08:33 PM
rjames
[quote name='TJB/914' post='2902423' date='Mar 24... Mar 27 2021, 09:44 PM
timothy_nd28 Maybe Ed will chime in, but from the pictures I ha... Mar 25 2021, 10:31 AM
jhynesrockmtn I just bought 2 Mar 28 2021, 10:20 AM
mate914 Just got one for the 9146 with Bluetooth.
Thanks Mar 28 2021, 12:50 PM
timothy_nd28 Two days left!! Mar 29 2021, 04:04 PM
914chris For a 914/6 application on original 2.0 liter 6, w... Mar 31 2021, 11:03 AM
Morrie
For a 914/6 application on original 2.0 liter 6, ... Mar 31 2021, 12:41 PM
123ignitionusa
For a 914/6 application on original 2.0 liter 6, ... Mar 31 2021, 06:19 PM
123ignitionusa
For a 914/6 application on original 2.0 liter 6, ... Mar 31 2021, 06:26 PM
timothy_nd28 Last Day!
Chris, I emailed Ed as well, hopefu... Mar 31 2021, 04:45 PM
mb911 Chris there is a big thread on the bird board on h... Mar 31 2021, 06:23 PM
123ignitionusa
Chris there is a big thread on the bird board on ... Mar 31 2021, 06:31 PM
mb911
[quote name='mb911' post='2904555' date='Mar 31 2... Mar 31 2021, 06:51 PM
mb911
Chris there is a big thread on the bird board on... Mar 31 2021, 06:57 PM
123ignitionusa
[quote name='123ignitionusa' post='2904558' date=... Mar 31 2021, 07:02 PM
123ignitionusa This should end the confusion regarding the Hkz CD... Apr 1 2021, 06:36 AM
timothy_nd28 Extra Bonus Day!
Coupon code has been edited ... Apr 1 2021, 09:23 AM
123ignitionusa This may interest some of you. Under the Help Tab ... Apr 1 2021, 09:56 AM
914chris Order Placed!! Thank you for the extension... Apr 1 2021, 06:55 PM
123ignitionusa
Order Placed!! Thank you for the extensio... Apr 1 2021, 07:50 PM
timothy_nd28 Thanks Ed, currently moving on to plan B with the ... Apr 2 2021, 04:39 PM
pete000 Here is the curve I ended up with my 74 1.8 L-Jet.... Apr 2 2021, 06:14 PM
7275914911
Here is the curve I ended up with my 74 1.8 L-Jet... Feb 21 2022, 10:00 PM
mgphoto Mine arrived today, D-Jet w/BT! Apr 8 2021, 05:16 PM
wbgoggans Anyone interested in doing another group buy? Jul 6 2021, 01:42 AM
Front yard mechanic
Ye... Jul 11 2021, 08:40 PM
FifthOrb
Y... Jul 13 2021, 10:55 AM
mepstein Yes Jul 11 2021, 08:51 PM
TX914 Yes Jul 14 2021, 05:35 AM
timothy_nd28 So I just now installed this bluetooth 123 dizzy o... Oct 17 2021, 07:25 PM
Front yard mechanic
So I just now installed this bluetooth 123 dizzy ... Oct 17 2021, 07:44 PM
jcd914
[quote name='timothy_nd28' post='2953282' date='O... Nov 15 2021, 11:26 PM
123ignitionusa
So I just now installed this bluetooth 123 dizzy ... Oct 26 2021, 06:53 PM
strawman I'm interested in a group buy for my wife... Nov 16 2021, 07:16 PM
Van B
I'm interested in a group buy for my wife... Feb 22 2022, 02:51 PM
relentless I'd be in for another GB for my '76 d-jet. Feb 22 2022, 02:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th January 2026 - 10:52 PM |
