Homemade solid tranny mount..., Had some time to kill.... |
Mike D. |
May 26 2003, 03:30 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
What do you think of these? I made them from a big hunk of billit aluminum. Center hole is same thickness as a stock tranny mount. Anybody want to take bets on dragging the transmission on the ground? Just kidding, I'm not sure if I trust myself. I guess I could install them then drive around a bit and see if anything is cracking...
-Mike D. Attached image(s) |
Mueller |
May 26 2003, 04:05 PM
They look similar to the units HPH sells, nothing fancy, but they work (IMG:style_emoticons/default/wink.gif)
Ideally, you'd want to have a radius in the corners, less likely to crack, but I don't think you'll ever have that problem with those !!!!! Good job (IMG:style_emoticons/default/mueba.gif) |
Lo-Fi Version | Time is now: 22nd May 2024 - 11:35 PM |
