goobstine |
Newbie ![]() Group: Members Posts: 30 Joined: 10-February 20 From: tucson az. Member No.: 23,908 Region Association: None ![]() |
will the monza corsa corvair 6 cyl air cooled engine work with a stock 914 transmission. ( not mount it is already mounted with adapter plate ) it is my understanding corvair engine rotates counter clockwise. How could this possibly operate with a stock 914 transmission? I have the transmission out of the car is there any way to check the rotation of the trans gears and things to see if i am getting the correct rotation out of my trans in a reverse fashion for the corvair counter clockwise action i will be receiving.
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,541 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
will the monza corsa corvair 6 cyl air cooled engine work with a stock 914 transmission. ( not mount it is already mounted with adapter plate ) it is my understanding corvair engine rotates counter clockwise. How could this possibly operate with a stock 914 transmission? I have the transmission out of the car is there any way to check the rotation of the trans gears and things to see if i am getting the correct rotation out of my trans in a reverse fashion for the corvair counter clockwise action i will be receiving. any help would be appreciated. There are companies that make (made) reverse rotation camshafts for Corvair engines. That is the proper way to put a Corvair engine against a 914 transmission. Others will tell you to just flip the ring and pinion in the transmission. But that is a bad idea. The 901 transmission uses helical cut gears inside it to reduce noise. Whenever helical cut gears are used, the "climb" against each other, putting thrust loads on the shafts. That load is transferred to the transmission case. If you reverse the rotation of the input shaft, you will reverse the "climb" of the gears. And that reverses the thrust loads on the transmission case. The engineers that designed the transmission did not provide thrust bearings for the reversed load. So now the transmission is running thrust loads against the magnesium case without the proper thrust bearings. This drastically shortens the life of the transmission. I hope that helps. Clay |
goobstine |
will the monza corsa corvair 6 cyl air cooled engine work with a stock 914 transmission. ( not mount it is already mounted with adapter plate ) it is my understanding corvair engine rotates counter clockwise. How could this possibly operate with a stock 914 transmission? I have the transmission out of the car is there any way to check the rotation of the trans gears and things to see if i am getting the correct rotation out of my trans in a reverse fashion for the corvair counter clockwise action i will be receiving. any help would be appreciated. There are companies that make (made) reverse rotation camshafts for Corvair engines. That is the proper way to put a Corvair engine against a 914 transmission. Others will tell you to just flip the ring and pinion in the transmission. But that is a bad idea. The 901 transmission uses helical cut gears inside it to reduce noise. Whenever helical cut gears are used, the "climb" against each other, putting thrust loads on the shafts. That load is transferred to the transmission case. If you reverse the rotation of the input shaft, you will reverse the "climb" of the gears. And that reverses the thrust loads on the transmission case. The engineers that designed the transmission did not provide thrust bearings for the reversed load. So now the transmission is running thrust loads against the magnesium case without the proper thrust bearings. This drastically shortens the life of the transmission. I hope that helps. Clay Thank you |
Lo-Fi Version | Time is now: 17th June 2024 - 02:15 AM |
