| RiqueMar |
Mar 29 2021, 05:43 PM
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,264 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California
Hi All,
Looking for suggestions on aftermarket blower fans for my 3.6 conversion. Nothing wrong with the stock 914 equipment, but would like to know what members have used to give the system a bit more 'Umph'. Pictures welcome, thanks in advance! |
| DRPHIL914 |
Mar 30 2021, 11:14 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
[quote name='RiqueMar' date='Mar 29 2021, 07:43 PM' post='2903951']
Hi All, Looking for suggestions on aftermarket blower fans for my 3.6 conversion. Nothing wrong with the stock 914 equipment, but would like to know what members have used to give the system a bit more 'Umph'. Pictures welcome, if you are talking about the front defrost/fresh air fan, i just rebuilt one using the new URO fan and motor assembly and on high speed its surprising how much air it moves, there is no need to do anything different for this, it moves a lot of air. - and if you want one that has a good resistor pack, i have 2 that are ready to be rebuilt, just need to order the replacment fan/motor, but i have them on my desk ready to install the new fan, i just have to order the new seals, will include a fan to housing seal and upper and lower airbox seal and flapper seal. - PM for details. if you have one that needs to be rebuilt you can send me as a core, i will take $100 off the price for this. Phil, |
| RiqueMar |
Mar 30 2021, 01:19 PM
if you are talking about the front defrost/fresh air fan, i just rebuilt one using the new URO fan and motor assembly and on high speed its surprising how much air it moves, there is no need to do anything different for this, it moves a lot of air. - and if you want one that has a good resistor pack, i have 2 that are ready to be rebuilt, just need to order the replacment fan/motor, but i have them on my desk ready to install the new fan, i just have to order the new seals, will include a fan to housing seal and upper and lower airbox seal and flapper seal. - PM for details. if you have one that needs to be rebuilt you can send me as a core, i will take $100 off the price for this. Phil, @DRPHIL914 Hi Phil - My mistake for not specifying int he original post. Not looking for the Fresh-air type blower, but rather something for the heating system. Thanks anyway! (IMG:style_emoticons/default/bye1.gif) |
| DRPHIL914 |
Mar 30 2021, 01:34 PM
if you are talking about the front defrost/fresh air fan, i just rebuilt one using the new URO fan and motor assembly and on high speed its surprising how much air it moves, there is no need to do anything different for this, it moves a lot of air. - and if you want one that has a good resistor pack, i have 2 that are ready to be rebuilt, just need to order the replacment fan/motor, but i have them on my desk ready to install the new fan, i just have to order the new seals, will include a fan to housing seal and upper and lower airbox seal and flapper seal. - PM for details. if you have one that needs to be rebuilt you can send me as a core, i will take $100 off the price for this. Phil, @DRPHIL914 Hi Phil - My mistake for not specifying int he original post. Not looking for the Fresh-air type blower, but rather something for the heating system. Thanks anyway! (IMG:style_emoticons/default/bye1.gif) @RiqueMar hey you might be able to try a bilge fan from a marine supply store, they could be mounted under there in line, but a good stock one should be fine, my rear aux fan for the heat also went bad and i sourced one from a member hear fairly cheap, like Clay said there are a lot of them out there. good luck! |
RiqueMar Aftermarket Blower-fan Mar 29 2021, 05:43 PM
jim_hoyland I considered modifing 911 footwell fans at one tim... Mar 29 2021, 05:47 PM
mepstein Talk to Jonny who does the electric a/c kits. He s... Mar 29 2021, 06:51 PM
ClayPerrine Are you talking about the fresh air fan?
Clay Mar 30 2021, 10:47 AM
RiqueMar
Clay
... Mar 30 2021, 01:15 PM
RiqueMar
hey you might be able to try a bilge fan from a m... Mar 30 2021, 01:41 PM
ClayPerrine That is a common engine compartment fan for a 914/... Mar 30 2021, 01:21 PM
mepstein Backdate the heat. Looks way cleaner and works gre... Mar 30 2021, 03:31 PM
RiqueMar
Backdate the heat. Looks way cleaner and works gr... Mar 30 2021, 03:41 PM
DRPHIL914 wow those are great! Mar 30 2021, 04:40 PM
Mark Henry A stock set up gets the best pressure at speed (3K... Mar 30 2021, 05:11 PM
mepstein BB’s are known for mediocre heat. An electric fa... Mar 30 2021, 06:41 PM
Steve I wonder how well this PMS adapter works with heat... Mar 30 2021, 07:59 PM
RiqueMar
I wonder how well this PMS adapter works with hea... Mar 30 2021, 08:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:15 PM |
