> Aftermarket Blower-fan, looking for suggestions
RiqueMar
post Mar 29 2021, 05:43 PM
Enrique Allen Mar
Hi All,
Looking for suggestions on aftermarket blower fans for my 3.6 conversion. Nothing wrong with the stock 914 equipment, but would like to know what members have used to give the system a bit more 'Umph'.
Pictures welcome, thanks in advance!
DRPHIL914
post Mar 30 2021, 11:14 AM
Dr. Phil
[quote name='RiqueMar' date='Mar 29 2021, 07:43 PM' post='2903951']
Hi All,
Pictures welcome,
if you are talking about the front defrost/fresh air fan, i just rebuilt one using the new URO fan and motor assembly and on high speed its surprising how much air it moves, there is no need to do anything different for this, it moves a lot of air.
- and if you want one that has a good resistor pack, i have 2 that are ready to be rebuilt, just need to order the replacment fan/motor, but i have them on my desk ready to install the new fan, i just have to order the new seals, will include a fan to housing seal and upper and lower airbox seal and flapper seal.
- PM for details. if you have one that needs to be rebuilt you can send me as a core, i will
take $100 off the price for this.
Phil,
RiqueMar
post Mar 30 2021, 01:19 PM
Enrique Allen Mar
QUOTE(DRPHIL914 @ Mar 30 2021, 10:14 AM) *
Phil,
@DRPHIL914
Hi Phil - My mistake for not specifying int he original post. Not looking for the Fresh-air type blower, but rather something for the heating system. Thanks anyway! (IMG:style_emoticons/default/bye1.gif)
DRPHIL914
post Mar 30 2021, 01:34 PM
Dr. Phil
QUOTE(RiqueMar @ Mar 30 2021, 03:19 PM) *
Phil,
@DRPHIL914
@RiqueMar
hey you might be able to try a bilge fan from a marine supply store, they could be mounted under there in line, but a good stock one should be fine, my rear aux fan for the heat also went bad and i sourced one from a member hear fairly cheap, like Clay said there are a lot of them out there. good luck!
RiqueMar
post Mar 30 2021, 01:41 PM
Enrique Allen Mar
QUOTE(DRPHIL914 @ Mar 30 2021, 12:34 PM) *
@DRPHIL914
You're on to my train-of-thought.
Originally, the previous installation had the heater-tube going up and over the engine. To make it look cleaner and supply more air-flow, was thinking to put a blower on each side of the engine, supplying each of the ducts that lead to the cabin, photo below.
I wasn't aware the motor in the photo was a stock 914/4 part, shows how much I know. I'll put up an add in the classified section. (IMG:style_emoticons/default/bye1.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 06:00 PM
