> GB 123ignition, Now offering bluetooth for DJET
timothy_nd28
post Mar 1 2021, 04:10 PM
Group Buy ending in less than 1 week!
I have heard nothing but great things about this aftermarket distributor. I won't be part or this group buy, because I already purchased one a few weeks ago for my Ljet. While speaking with Ed at 123ignition, I told him that it might be good time to set up a group buy for the month of March, to help get our 914's running better for summer driving (IMG:style_emoticons/default/driving.gif)
Ed told me: 1-5 people will get 5% off. 6-10 people, would be 10% off. 11+ people, is 10% off and free shipping within the US. Pretty sure Ed said that if we get 1000 people, he would fly out to each of our houses and personally install the new dizzy himself! (kidding)
Group Buy 3/1/2021 thru 3/31/2021
Coupon code: 914world21
Please order using this site: 123ignitionusa.com
I borrowed some links from the last group buy (thanks Rob)! Ed mentioned that the Djet version dizzy still does not have the bluetooth function.
* Newest bluetooth model for D-jet
1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet.
2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet.
3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users.
4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI
5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet.
This group buy will also apply for other engines such as the 911 six cylinders.
https://www.youtube.com/watch?v=3wZ2xj6SAfI
914chris
post Mar 31 2021, 11:03 AM
For a 914/6 application on original 2.0 liter 6, would I remove the CDI?
Website description says:
Suitable for engines without HKZ (CDI) unit and first generation HKZ unit ( 3 wires )
Warning: Don’t use the original HKZ (CDI) coil direct on the 123ignition.
I believe I have the HKZ unit with 3 wires. Says it is suitable to use with first gen, but then says don't use it direct on the 123ignition. What does "direct on" mean?
123ignitionusa
post Mar 31 2021, 06:19 PM
QUOTE(914chris @ Mar 31 2021, 12:03 PM) *
Hi
I am not sure how they are wired. So I cannot answer that tonight as the mfg is closed at the moment. I will extend the buy 24hrs to see if I can get an answer.
As for the gear - There are two different pitched gears depending on what motor you have.
The 2.4 2.7 and 3.3 when looking at them sitting in front of you are pitched from left up to the right.
The 3.0 SC is pitched from right to up to the left.
Over the years motors are worked on and rearranged cams from different motors are used and gearing changes. Because of this you need to confirm what you have. A picture is supplied to compare. Almost all are pitched from left up to the right.
I have had customers order one only to find out they have the other. You mus to a visual comparison. See attachment
In addition original gears have a larger inside diameter than the 123 and so cannot be used unless a bushing adapter is used.
123ignitionusa Webpage
timothy_nd28   GB 123ignition   Mar 1 2021, 04:10 PM
burlybryan   Great job setting this up. Been planning on upgra...   Mar 1 2021, 06:12 PM
Morph914   Rats!!! I just purchased one last mont...   Mar 1 2021, 06:19 PM
warpig   Rats!!! I just purchased one last mon...   Mar 19 2021, 09:49 PM
mb911   I bought this setup last year for my -6 and hope t...   Mar 1 2021, 06:22 PM
VaccaRabite   I have set these up on a 914 before. Its easy and...   Mar 1 2021, 06:47 PM
BillC   @timothy_nd28 Thank you very much for setting th...   Mar 1 2021, 07:20 PM
123ignitionusa   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 1 2021, 08:42 PM
Morrie   Unlike the last GB, for this one, orders will be...   Mar 19 2021, 02:59 PM
Sycolyst   Perfect timing...I'm in. I was planning to pu...   Mar 1 2021, 08:02 PM
timothy_nd28   Great question, I'm somewhat fuzzy on how Ed w...   Mar 1 2021, 08:13 PM
Robarabian   I have one for my 4 and one for the pending 6. Any...   Mar 2 2021, 09:23 AM
timothy_nd28   I have one for my 4 and one for the pending 6. An...   Mar 2 2021, 04:44 PM
Rand   We have been through this. I think it's pretty...   Mar 2 2021, 08:08 PM
72914wrx   I’m in !   Mar 2 2021, 10:32 PM
Highland   Just wondering if the 123 ignition might help with...   Mar 7 2021, 05:04 PM
StratPlayer   I will be selling my 123 dizzy for a DJet soon. I...   Mar 7 2021, 08:37 PM
mate914   What happens if you have the bluetooth+ and you us...   Mar 8 2021, 08:08 AM
123ignitionusa   What happens if you have the bluetooth+ and you u...   Mar 8 2021, 12:16 PM
timothy_nd28   :bump: Another two weeks left in this group buy, ...   Mar 15 2021, 08:22 PM
123ignitionusa   Don't forget to use coupon code 914world21   Mar 16 2021, 05:20 PM
tyfighter123   Just ordered one. Thanks   Mar 16 2021, 10:23 PM
123ignitionusa   New release - Programmable Bluetooth with D-Jet ou...   Mar 17 2021, 10:45 AM
DTMLGND   [size=6]New release - Programmable Bluetooth with...   Mar 31 2021, 08:01 PM
orthobiz   One time I looked and saw two detailed YouTube vid...   Mar 17 2021, 10:48 AM
dax1969   One time I looked and saw two detailed YouTube vi...   Mar 19 2021, 03:29 AM
123ignitionusa   Click this link Instructional Videos or click her...   Mar 21 2021, 12:50 PM
timothy_nd28   :agree: I concluded that most 914 people are cam...   Mar 17 2021, 11:00 AM
timothy_nd28   Updated post one to include the new Djet bluetooth...   Mar 17 2021, 12:43 PM
pete000   I installed a blue tooth version in my 74 1.8 L-Je...   Mar 17 2021, 05:00 PM
timothy_nd28   I bought the bluetooth version for my Ljet, and wi...   Mar 17 2021, 06:20 PM
dax1969   Damn...just bought a 123 ignition for my 74 2.0 dj...   Mar 19 2021, 03:35 AM
jhynesrockmtn   I'm contemplating two of these. I have a stoc...   Mar 19 2021, 08:03 AM
CMONNETT   Has anyone else had a problem with these 123's...   Mar 19 2021, 10:08 AM
VaccaRabite   Has anyone else had a problem with these 123...   Mar 19 2021, 10:33 AM
rjames   Has anyone else had a problem with these 123...   Mar 19 2021, 11:35 AM
CMONNETT   Has anyone else had a problem with these 123...   Mar 19 2021, 03:00 PM
123ignitionusa   [quote name='rjames' post='2900902' date='Mar 19 ...   Mar 19 2021, 03:18 PM
CMONNETT   [quote name='rjames' post='2900902' date='Mar 19...   Mar 19 2021, 03:48 PM
123ignitionusa   Hey Guys we are at 5. From here forward 10% discou...   Mar 19 2021, 03:14 PM
DRPHIL914   what would be the advantage of having the blue too...   Mar 21 2021, 08:02 AM
75914-L20C   I just ordered a bluetooth unit for my '75 L-j...   Mar 21 2021, 12:47 PM
pete000   Just ordered mine. Thanks for setting this up!   Mar 21 2021, 07:11 PM
burlybryan   Order placed for D-Jet with BT   Mar 24 2021, 08:18 AM
BillJ   oh man -JUST finished my 2056 and have the 123 non...   Mar 24 2021, 08:45 AM
pstank   Ordered L-Jet option! Super excited for this ...   Mar 24 2021, 08:52 AM
timothy_nd28   One Week Left! And we definitely hit the quo...   Mar 24 2021, 09:54 AM
Morrie   [size=4][b]One Week Left! And we definitely...   Mar 24 2021, 10:59 AM
Samuelrocky   Just ordered today 3-24-21.   Mar 24 2021, 12:55 PM
123ignitionusa   Thanks for your patronage. Orders are now at 11. ...   Mar 24 2021, 02:33 PM
TJB/914   Thanks for your patronage. Orders are now at 11. ...   Mar 24 2021, 04:28 PM
123ignitionusa   Thanks for your patronage. Orders are now at 11....   Mar 27 2021, 08:33 PM
rjames   [quote name='TJB/914' post='2902423' date='Mar 24...   Mar 27 2021, 09:44 PM
timothy_nd28   Maybe Ed will chime in, but from the pictures I ha...   Mar 25 2021, 10:31 AM
jhynesrockmtn   I just bought 2   Mar 28 2021, 10:20 AM
mate914   Just got one for the 9146 with Bluetooth. Thanks   Mar 28 2021, 12:50 PM
timothy_nd28   Two days left!!   Mar 29 2021, 04:04 PM
914chris   For a 914/6 application on original 2.0 liter 6, w...   Mar 31 2021, 11:03 AM
Morrie   For a 914/6 application on original 2.0 liter 6, ...   Mar 31 2021, 12:41 PM
123ignitionusa   For a 914/6 application on original 2.0 liter 6, ...   Mar 31 2021, 06:19 PM
123ignitionusa   For a 914/6 application on original 2.0 liter 6, ...   Mar 31 2021, 06:26 PM
timothy_nd28   Last Day! Chris, I emailed Ed as well, hopefu...   Mar 31 2021, 04:45 PM
mb911   Chris there is a big thread on the bird board on h...   Mar 31 2021, 06:23 PM
123ignitionusa   Chris there is a big thread on the bird board on ...   Mar 31 2021, 06:31 PM
mb911   [quote name='mb911' post='2904555' date='Mar 31 2...   Mar 31 2021, 06:51 PM
mb911   Chris there is a big thread on the bird board on...   Mar 31 2021, 06:57 PM
123ignitionusa   [quote name='123ignitionusa' post='2904558' date=...   Mar 31 2021, 07:02 PM
123ignitionusa   This should end the confusion regarding the Hkz CD...   Apr 1 2021, 06:36 AM
timothy_nd28   Extra Bonus Day! Coupon code has been edited ...   Apr 1 2021, 09:23 AM
123ignitionusa   This may interest some of you. Under the Help Tab ...   Apr 1 2021, 09:56 AM
914chris   Order Placed!! Thank you for the extension...   Apr 1 2021, 06:55 PM
123ignitionusa   Order Placed!! Thank you for the extensio...   Apr 1 2021, 07:50 PM
timothy_nd28   Thanks Ed, currently moving on to plan B with the ...   Apr 2 2021, 04:39 PM
pete000   Here is the curve I ended up with my 74 1.8 L-Jet....   Apr 2 2021, 06:14 PM
7275914911   Here is the curve I ended up with my 74 1.8 L-Jet...   Feb 21 2022, 10:00 PM
mgphoto   Mine arrived today, D-Jet w/BT!   Apr 8 2021, 05:16 PM
wbgoggans   Anyone interested in doing another group buy?   Jul 6 2021, 01:42 AM
Front yard mechanic   Anyone interested in doing another group buy? Ye...   Jul 11 2021, 08:40 PM
FifthOrb   Anyone interested in doing another group buy? Y...   Jul 13 2021, 10:55 AM
mepstein   Yes   Jul 11 2021, 08:51 PM
TX914   Yes   Jul 14 2021, 05:35 AM
timothy_nd28   So I just now installed this bluetooth 123 dizzy o...   Oct 17 2021, 07:25 PM
Front yard mechanic   So I just now installed this bluetooth 123 dizzy ...   Oct 17 2021, 07:44 PM
jcd914   [quote name='timothy_nd28' post='2953282' date='O...   Nov 15 2021, 11:26 PM
123ignitionusa   So I just now installed this bluetooth 123 dizzy ...   Oct 26 2021, 06:53 PM
strawman   I'm interested in a group buy for my wife...   Nov 16 2021, 07:16 PM
Van B   I'm interested in a group buy for my wife...   Feb 22 2022, 02:51 PM
relentless   I'd be in for another GB for my '76 d-jet.   Feb 22 2022, 02:44 PM
- Lo-Fi Version Time is now: 7th January 2026 - 10:53 PM
