Suggestions? |
Suggestions? |
Pursang |
Apr 1 2021, 06:21 PM
Member Group: Members Posts: 233 Joined: 19-January 13 From: Beaverton Member No.: 15,386 Region Association: Pacific Northwest |
I am looking for a way to secure that rubber soundproofing pad that fits against the passenger wall in the engine compartment. Those metal tabs at the top seem pretty useless. It looks like some adhesive might have been applied with a tube at some time but the years and the engine heat have broken that seal.
I was thinking about small bolts and grommets through those metal tabs but I am afraid that they would eventually just rip through the pad. Would you apply adhesive again and, if so, what brand? Any other ideas? (IMG:style_emoticons/default/confused24.gif) Thanks. |
bkrantz |
Apr 1 2021, 07:20 PM
914 Guru Group: Members Posts: 7,803 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
You might hear lots of push back on mounting the original pad or (or any pad) since it tends to trap water and accelerate rust. Whatever you do, make sure water can drain out the bottom.
ClayPerrine |
Apr 2 2021, 10:04 AM
Life's been good to me so far..... Group: Admin Posts: 15,519 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You might hear lots of push back on mounting the original pad or (or any pad) since it tends to trap water and accelerate rust. Whatever you do, make sure water can drain out the bottom. (IMG:style_emoticons/default/agree.gif) I also worry that it will fall down and block the engine fan, leading to catastrophic overheating of the engine. So I just insulate on the inside. Clay |
Lo-Fi Version | Time is now: 9th June 2024 - 02:07 PM |
