Transmission seals,, I just came out of the shed... |
Trekkor |
Dec 29 2004, 02:36 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Not bad, took about 90 mins. I took my time.
Had a barley pop (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) Here's the input shaft seal. KT Attached image(s) |
ClayPerrine |
Dec 29 2004, 08:03 AM
Life's been good to me so far..... Group: Admin Posts: 15,501 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I hope you removed the pin on the BOTTOM of the shift console and not the top.
The roll pin in the top of the shaft seems to be a one use item. When you remove it and put it back, it is notorious for shearing off inside the transmission. BTDT. In the hills of Austin. Since then, I always pull the bottom pin... it's much easier to replace. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:06 AM |
