> Main Targa seal, Not having any success
Morph914
post Apr 3 2021, 09:43 AM
I would take installing the air box 5 times, over putting this seal in. I cannot get it to conform at the top where it makes the bend. (IMG:style_emoticons/default/headbang.gif)
I have tried heating the rubber in this area to get it to conform to the bend without any luck. The 914 rubber piece is reinforced in the exact location that it needs to make the bend. Not sure what to do at this point. (IMG:style_emoticons/default/hissyfit.gif)
You can see where the original piece is bent.
Garland
post Apr 3 2021, 02:30 PM
Restoration Fanatic
I think when I did mine I left the center part off the windshield frame, fitted the verticals first, then stretched the horizontal across. It was a tight fit. Also made sure the channels in the chrome trim of the A pillars we’re the correct width.
Morph914   Main Targa seal   Apr 3 2021, 09:43 AM
AFyrigos   I just received a new rubber as well. Haven’t st...   Apr 3 2021, 10:17 AM
Morph914   I just received a new rubber as well. Haven’t s...   Apr 3 2021, 12:28 PM
mgphoto   I did this about a year ago, work from the top dow...   Apr 3 2021, 11:39 AM
Morph914   I did this about a year ago, work from the top do...   Apr 3 2021, 12:30 PM
Garland   I think when I did mine I left the center part off...   Apr 3 2021, 02:30 PM
forrestkhaag   I did this fix very recently and found that there ...   Apr 3 2021, 05:36 PM
Morph914   I did this fix very recently and found that there...   Apr 3 2021, 08:45 PM
windforfun   Be patient & take another look at the problem.   Apr 3 2021, 08:11 PM
Mikey914   The rubber can only be molded when it's in it...   Apr 4 2021, 04:24 AM
Morph914   The rubber can only be molded when it's in it...   Apr 4 2021, 11:33 AM
sb914   I have never been able to put my targa top on sinc...   Apr 4 2021, 11:44 AM
Midway   I have never been able to put my targa top on sin...   Apr 5 2021, 06:16 AM
zfisher6164   See if this helps, the seal went on easier then I ...   Apr 4 2021, 11:53 AM
Mikey914   This is not an easy seal to replace. The key is to...   Apr 4 2021, 04:04 PM
windforfun   I admire your tenacity. My seals are still kosher...   Apr 4 2021, 06:06 PM
Literati914   .. In the picture, I have marked where the hard ...   Apr 4 2021, 07:48 PM
Mikey914   [quote name='Morph914' post='2905445' date='Apr 4...   Apr 5 2021, 10:49 PM
windforfun   Let sleeping dogs sleep. Some things are best lef...   Apr 5 2021, 07:09 PM
Morph914   Ok, I guess I will need to exchange mine for one t...   Apr 6 2021, 10:09 AM
Mikey914   That is rubber and part of the corner block. It...   Apr 6 2021, 10:38 AM
Morph914   That is rubber and part of the corner block. It...   Apr 6 2021, 12:09 PM
PCH   After spending the whole weekend unsuccessfully tr...   Apr 6 2021, 12:52 PM
horizontally-opposed   After spending the whole weekend unsuccessfully t...   Apr 7 2021, 10:12 AM
PCH   After spending the whole weekend unsuccessfully ...   Apr 7 2021, 11:03 AM
Mikey914   The internal joining block should be about 2-1/2...   Apr 7 2021, 10:19 AM
Morph914   The internal joining block should be about 2-1/2...   Apr 7 2021, 07:43 PM
76-914   The internal joining block should be about 2-1/2...   Apr 7 2021, 08:07 PM
Mikey914   More detail on closure This is a new seal out of t...   Apr 7 2021, 10:34 AM
Mikey914   We do appreciate your support and are striving to ...   Apr 7 2021, 09:12 PM
- Lo-Fi Version Time is now: 22nd October 2026 - 08:05 PM
