Mr Gasket 4-7 PSI for Weber IDF too much pressure? |
Tdskip |
Apr 3 2021, 07:31 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
This for a car that us set up with a front trunk mounted fuel pump (prior owner) that I suspect needs the Facet pump replaced. I know the low range of 4 PSI is fine but am concerned that the upper range list on the pump is too much.
Thanks and hope everyone has had a good Saturday. |
bdstone914 |
Apr 3 2021, 09:10 PM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
This for a car that us set up with a front trunk mounted fuel pump (prior owner) that I suspect needs the Facet pump replaced. I know the low range of 4 PSI is fine but am concerned that the upper range list on the pump is too much. Thanks and hope everyone has had a good Saturday. Is there a fuel pressure regulator? Every set of carbs is different. I had a set that had to be dialed down to 2.5 psi to not overflow. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:42 AM |
