Mr Gasket 4-7 PSI for Weber IDF too much pressure? |
Tdskip |
Apr 3 2021, 07:31 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
This for a car that us set up with a front trunk mounted fuel pump (prior owner) that I suspect needs the Facet pump replaced. I know the low range of 4 PSI is fine but am concerned that the upper range list on the pump is too much.
Thanks and hope everyone has had a good Saturday. |
9146C |
Apr 4 2021, 06:49 AM
Member Group: Members Posts: 228 Joined: 14-September 19 From: US Member No.: 23,460 Region Association: None |
I agree with Bruce above...always try to regulate fuel pressure ahead of the carbs.
Attached is a photo of my regulator set up with dual 40 Webers...set to 3-1/2 psi (with a gauge on the regulator). I just went with the Delphi FD0037 fuel pump from Napa...we'll see how that works in the long run. It's an all-metal pump case with 1/4" NPT fittings on both ends...allows different size barbed ends (available at any hardware store) to be fitted on each end depending on fuel line size. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 03:55 PM |
