damn vacuum leak |
damn vacuum leak |
dax1969 |
Apr 6 2021, 05:19 AM
Member Group: Members Posts: 362 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
I was so close on solving the last vacuum leak and created another one (IMG:style_emoticons/default/sad.gif)
All hoses, injector seals etc replaced and while doing the "spray test" with brake cleaner I noticed that the connecting rubber on cylinder nr 3 was bad. Replaced the four connecting hoses and installed new intake manifold gaskets. Did the spraytest again and it all looks good on the connecting rubbers but now I have a leak on the intake manifold on the passenger side. pffft. Intake gaskets are new and installed them dry...ordered another new one but should I put some sealant on ? Somebody suggested to add a paper gasket as well but I see no reason why, the new intake gasket should do the job I guess. Idle is at 1200 rpm and can't get it lower due to that bloody leak any suggestions ? thks in advance Dax |
Mark Henry |
Apr 6 2021, 05:53 AM
I grease my intake gaskets, I just rub in enough to stain the gasket.
You can make a cheap DIY smoke machine out of a paint can, cheap soldering iron, hose and some minerial oil. Look for a how to on youtube. |
Lo-Fi Version | Time is now: 7th June 2024 - 02:26 AM |
