| tsvo |
Apr 7 2021, 06:22 PM
Member ![]() ![]() Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest
Hello, my emergency brake no longer has any resistance on the lever when you pull on it. It does not lock or engage the brake. Where do I start to find the issue?
Regards, Terry |
| pcdarks |
Apr 7 2021, 07:02 PM
Member ![]() ![]() Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
You have a single cable about 8 inches long that then splits and pulls left and right. This is located under the drivers seat and is easily accessible once the seat is out. there is a plate covering it with two small screws.The other ends go directly to the rear calipers.
tsvo Emergency brake Apr 7 2021, 06:22 PM
Dave_Darling Check to see if the cables are still attached to t... Apr 7 2021, 06:45 PM
tsvo
Check to see if the cables are still attached to ... Apr 7 2021, 06:51 PM
tsvo
Check to see if the cables are still attached to ... Apr 8 2021, 06:27 PM
bdstone914
Check to see if the cables are still attached to... Apr 8 2021, 06:43 PM
tsvo
You have a single cable about 8 inches long that ... Apr 7 2021, 07:11 PM
tsvo
You have a single cable about 8 inches long that ... Apr 8 2021, 06:27 PM
Olympic 914 May also need to set the air gap on the pads.
.00... Apr 8 2021, 05:51 PM
tsvo
.0... Apr 8 2021, 06:26 PM
Spoke Did the ebrake ever work or is this a new issue? Apr 8 2021, 06:58 PM
tsvo
... Apr 8 2021, 07:08 PM
bbrock
Did the ebrake ever work or is this a new issue?... Apr 8 2021, 07:51 PM
tsvo
[quote name='tsvo' post='2906644' date='Apr 8 202... Apr 8 2021, 08:04 PM
bbrock
[quote name='tsvo' post='2906644' date='Apr 8 20... Apr 8 2021, 09:54 PM
Dion Visual aide Apr 9 2021, 04:41 AM
tsvo
Visual aide
That is absolutely it. Mine is not ... Apr 9 2021, 05:25 AM
ClayPerrine
That is absolutely it. Mine is not connected. Se... Apr 9 2021, 05:55 AM
tsvo
That is absolutely it. Mine is not connected. S... Apr 9 2021, 06:11 AM
BeatNavy If you look in Dion's second pic above you can... Apr 9 2021, 06:30 AM
tsvo
If you look in Dion's second pic above you ca... Apr 9 2021, 06:35 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th September 2026 - 12:40 PM |
