> Emergency brake, No resistance on lever, does not engage
tsvo
post Apr 7 2021, 06:22 PM
Hello, my emergency brake no longer has any resistance on the lever when you pull on it. It does not lock or engage the brake. Where do I start to find the issue?
Regards,
Terry
pcdarks
post Apr 7 2021, 07:02 PM
You have a single cable about 8 inches long that then splits and pulls left and right. This is located under the drivers seat and is easily accessible once the seat is out. there is a plate covering it with two small screws.The other ends go directly to the rear calipers.
tsvo
post Apr 8 2021, 06:27 PM
QUOTE(pcdarks @ Apr 7 2021, 08:02 PM) *
One more question, besides the brake cable wire, what is the second wire under the driver's seat?
tsvo   Emergency brake   Apr 7 2021, 06:22 PM
Dave_Darling   Check to see if the cables are still attached to t...   Apr 7 2021, 06:45 PM
tsvo   Check to see if the cables are still attached to ...   Apr 7 2021, 06:51 PM
tsvo   Check to see if the cables are still attached to ...   Apr 8 2021, 06:27 PM
bdstone914   Check to see if the cables are still attached to...   Apr 8 2021, 06:43 PM
pcdarks   You have a single cable about 8 inches long that t...   Apr 7 2021, 07:02 PM
tsvo   You have a single cable about 8 inches long that ...   Apr 7 2021, 07:11 PM
tsvo   You have a single cable about 8 inches long that ...   Apr 8 2021, 06:27 PM
Olympic 914   May also need to set the air gap on the pads. .00...   Apr 8 2021, 05:51 PM
tsvo   May also need to set the air gap on the pads. .0...   Apr 8 2021, 06:26 PM
Spoke   Did the ebrake ever work or is this a new issue?   Apr 8 2021, 06:58 PM
tsvo   Did the ebrake ever work or is this a new issue? ...   Apr 8 2021, 07:08 PM
bbrock   Did the ebrake ever work or is this a new issue?...   Apr 8 2021, 07:51 PM
tsvo   [quote name='tsvo' post='2906644' date='Apr 8 202...   Apr 8 2021, 08:04 PM
bbrock   [quote name='tsvo' post='2906644' date='Apr 8 20...   Apr 8 2021, 09:54 PM
Dion   Visual aide   Apr 9 2021, 04:41 AM
tsvo   Visual aide That is absolutely it. Mine is not ...   Apr 9 2021, 05:25 AM
ClayPerrine   That is absolutely it. Mine is not connected. Se...   Apr 9 2021, 05:55 AM
tsvo   That is absolutely it. Mine is not connected. S...   Apr 9 2021, 06:11 AM
BeatNavy   If you look in Dion's second pic above you can...   Apr 9 2021, 06:30 AM
tsvo   If you look in Dion's second pic above you ca...   Apr 9 2021, 06:35 AM
- Lo-Fi Version Time is now: 14th September 2026 - 12:40 PM
