| tsvo |
Apr 7 2021, 06:22 PM
Member ![]() ![]() Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest
Hello, my emergency brake no longer has any resistance on the lever when you pull on it. It does not lock or engage the brake. Where do I start to find the issue?
Regards, Terry |
| Spoke |
Apr 8 2021, 06:58 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,427 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Did the ebrake ever work or is this a new issue?
| tsvo |
Apr 8 2021, 07:08 PM
Did the ebrake ever work or is this a new issue? I removed the seat. The cable from the brake looked good. I wiggled it around a little and the brake works fine. Kind of concerns me so ce I didn't really do anything. While under there I found this second wire, what is it? Fasten seat belt sensor? It wasn't attached to anything. It was just kind of stuck in the hole on the floor near the base of the brake. Perhaps it was interfering? |
| bbrock |
Apr 8 2021, 07:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Did the ebrake ever work or is this a new issue? I removed the seat. The cable from the brake looked good. I wiggled it around a little and the brake works fine. Kind of concerns me so ce I didn't really do anything. While under there I found this second wire, what is it? Fasten seat belt sensor? It wasn't attached to anything. It was just kind of stuck in the hole on the floor near the base of the brake. Perhaps it was interfering? Maybe the wire to the brake light switch? Is it brown? |
tsvo Emergency brake Apr 7 2021, 06:22 PM
Dave_Darling Check to see if the cables are still attached to t... Apr 7 2021, 06:45 PM
tsvo
Check to see if the cables are still attached to ... Apr 7 2021, 06:51 PM
tsvo
Check to see if the cables are still attached to ... Apr 8 2021, 06:27 PM
bdstone914
Check to see if the cables are still attached to... Apr 8 2021, 06:43 PM
pcdarks You have a single cable about 8 inches long that t... Apr 7 2021, 07:02 PM
tsvo
You have a single cable about 8 inches long that ... Apr 7 2021, 07:11 PM
tsvo
You have a single cable about 8 inches long that ... Apr 8 2021, 06:27 PM
Olympic 914 May also need to set the air gap on the pads.
.00... Apr 8 2021, 05:51 PM
tsvo
.0... Apr 8 2021, 06:26 PM
tsvo
[quote name='tsvo' post='2906644' date='Apr 8 202... Apr 8 2021, 08:04 PM
bbrock
[quote name='tsvo' post='2906644' date='Apr 8 20... Apr 8 2021, 09:54 PM
Dion Visual aide Apr 9 2021, 04:41 AM
tsvo
Visual aide
That is absolutely it. Mine is not ... Apr 9 2021, 05:25 AM
ClayPerrine
That is absolutely it. Mine is not connected. Se... Apr 9 2021, 05:55 AM
tsvo
That is absolutely it. Mine is not connected. S... Apr 9 2021, 06:11 AM
BeatNavy If you look in Dion's second pic above you can... Apr 9 2021, 06:30 AM
tsvo
If you look in Dion's second pic above you ca... Apr 9 2021, 06:35 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th September 2026 - 12:40 PM |
