| adolimpio |
Apr 7 2021, 05:10 PM
Art ![]() ![]() Group: Members Posts: 190 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States
I finished building my engine, which uses a 2.0 crank in a 1.7 case.
My crank end play is 0.0125 without any shims. I've seen that you should use a minimum of 3 shims, but even a single smallest shim puts me at the edge of spec - 0.0125 - .00945 = 0.003. Is this OK? Did I do something wrong assembling? |
| 02loftsmoor |
Apr 8 2021, 08:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region
I'm replacing the Flywheel .
i have Three .010" shims in, and i have .012" end play. what do i need to change?? |
adolimpio Flywheel / crank end play Apr 7 2021, 05:10 PM
Bleyseng Did you set the end play before installing the rea... Apr 7 2021, 08:23 PM
adolimpio Yes, seal is not installed yet. Apr 7 2021, 09:19 PM
adolimpio Problem solve, it was caused by the DACO.
I'm... Apr 8 2021, 04:35 PM
Mark Henry
i have Three .01... Apr 9 2021, 09:56 AM
02loftsmoor
i have Three .0... Apr 9 2021, 06:59 PM
iankarr The shims are available in a range of sizes. You... Apr 8 2021, 09:02 PM
02loftsmoor
The shims are available in a range of sizes. You... Apr 8 2021, 09:19 PM
iankarr Wow...just checked the type 4 store. You're ri... Apr 9 2021, 08:53 AM
02loftsmoor
Wow...just checked the type 4 store. You're r... Apr 11 2021, 08:24 AM
Mark Henry When you get the shims be sure to test fit first. ... Apr 10 2021, 06:13 AM
02loftsmoor
When you get the shims be sure to test fit first.... Apr 11 2021, 08:18 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th September 2026 - 11:53 PM |
