> Flywheel / crank end play, Did I do something wrong?
adolimpio
post Apr 7 2021, 05:10 PM
Art
I finished building my engine, which uses a 2.0 crank in a 1.7 case.
My crank end play is 0.0125 without any shims.
I've seen that you should use a minimum of 3 shims, but even a single smallest shim puts me at the edge of spec - 0.0125 - .00945 = 0.003.
Is this OK?
Did I do something wrong assembling?
iankarr
post Apr 8 2021, 09:02 PM
The shims are available in a range of sizes. You'll need to calculate which thicknesses are needed to arrive a total end play of .003 - .005. Remember this is expressed in thousandths of an inch. It's confusing because the shims are sold by the dimension in mm. It's best to order a variety so you have them on hand when you're sorting it all out. You can always return the unused ones. They're not expensive regardless.
02loftsmoor
post Apr 8 2021, 09:19 PM
QUOTE(iankarr @ Apr 8 2021, 10:02 PM) *
where do get cheap shims? i saw some for $34 ,, $8 seems he going rate
- Lo-Fi Version Time is now: 8th September 2026 - 11:53 PM
