> Emergency brake, No resistance on lever, does not engage
tsvo
post Apr 7 2021, 06:22 PM
Hello, my emergency brake no longer has any resistance on the lever when you pull on it. It does not lock or engage the brake. Where do I start to find the issue?
Regards,
Terry
Spoke
post Apr 8 2021, 06:58 PM
Jerry
Did the ebrake ever work or is this a new issue?
tsvo
post Apr 8 2021, 07:08 PM
QUOTE(Spoke @ Apr 8 2021, 07:58 PM) *
I removed the seat. The cable from the brake looked good. I wiggled it around a little and the brake works fine. Kind of concerns me so ce I didn't really do anything.
While under there I found this second wire, what is it? Fasten seat belt sensor? It wasn't attached to anything. It was just kind of stuck in the hole on the floor near the base of the brake. Perhaps it was interfering?
bbrock
post Apr 8 2021, 07:51 PM
QUOTE(tsvo @ Apr 8 2021, 06:08 PM) *
Maybe the wire to the brake light switch? Is it brown?
tsvo
post Apr 8 2021, 08:04 PM
QUOTE(bbrock @ Apr 8 2021, 08:51 PM) *
Yes, it is brown.
bbrock
post Apr 8 2021, 09:54 PM
QUOTE(tsvo @ Apr 8 2021, 07:04 PM) *
Yes, it is brown.
Sounds like the wire that should run to the contact switch that the e-brake handle pushes down and rests on when it is off.
tsvo   Emergency brake   Apr 7 2021, 06:22 PM
Dave_Darling   Check to see if the cables are still attached to t...   Apr 7 2021, 06:45 PM
tsvo   Check to see if the cables are still attached to ...   Apr 7 2021, 06:51 PM
tsvo   Check to see if the cables are still attached to ...   Apr 8 2021, 06:27 PM
bdstone914   Check to see if the cables are still attached to...   Apr 8 2021, 06:43 PM
pcdarks   You have a single cable about 8 inches long that t...   Apr 7 2021, 07:02 PM
tsvo   You have a single cable about 8 inches long that ...   Apr 7 2021, 07:11 PM
tsvo   You have a single cable about 8 inches long that ...   Apr 8 2021, 06:27 PM
Olympic 914   May also need to set the air gap on the pads. .00...   Apr 8 2021, 05:51 PM
tsvo   May also need to set the air gap on the pads. .0...   Apr 8 2021, 06:26 PM
Spoke   Did the ebrake ever work or is this a new issue?   Apr 8 2021, 06:58 PM
tsvo   Did the ebrake ever work or is this a new issue? ...   Apr 8 2021, 07:08 PM
bbrock   Did the ebrake ever work or is this a new issue?...   Apr 8 2021, 07:51 PM
tsvo   [quote name='tsvo' post='2906644' date='Apr 8 202...   Apr 8 2021, 08:04 PM
bbrock   [quote name='tsvo' post='2906644' date='Apr 8 20...   Apr 8 2021, 09:54 PM
Dion   Visual aide   Apr 9 2021, 04:41 AM
tsvo   Visual aide That is absolutely it. Mine is not ...   Apr 9 2021, 05:25 AM
ClayPerrine   That is absolutely it. Mine is not connected. Se...   Apr 9 2021, 05:55 AM
tsvo   That is absolutely it. Mine is not connected. S...   Apr 9 2021, 06:11 AM
BeatNavy   If you look in Dion's second pic above you can...   Apr 9 2021, 06:30 AM
tsvo   If you look in Dion's second pic above you ca...   Apr 9 2021, 06:35 AM
- Lo-Fi Version Time is now: 14th September 2026 - 12:40 PM
