| tsvo |
Apr 7 2021, 06:22 PM
Member ![]() ![]() Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest
Hello, my emergency brake no longer has any resistance on the lever when you pull on it. It does not lock or engage the brake. Where do I start to find the issue?
Regards, Terry |
| BeatNavy |
Apr 9 2021, 06:30 AM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,967 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
If you look in Dion's second pic above you can see the switch is mounted right into that metal cross member on the floor pan and then grounded to the chassis. Get a replacement switch and insert it into that square shaped hole on the metal cross member. Then make sure the wire is grounded either by connecting it what's left of the original wire or doing it in a manner similar to what Dion did.
Just to be clear, the e-brake is a mechanical setup, though. In and of itself this isn't causing the original issue you described (unless pieces of your switch are interfering with operation somehow). |
| tsvo |
Apr 9 2021, 06:35 AM
If you look in Dion's second pic above you can see the switch is mounted right into that metal cross member on the floor pan and then grounded to the chassis. Get a replacement switch and insert it into that square shaped hole on the metal cross member. Then make sure the wire is grounded either by connecting it what's left of the original wire or doing it in a manner to what Dion did. Just to be clear, the e-brake is a mechanical setup, though. In and of itself this isn't causing the original issue you described (unless pieces of your switch are interfering with operation somehow). Thank you Rob, I will get the new switch. Your second comment is what I am still concerned about. I really didn't do anything and now the e brake works. I will replace the switch and have to wait and see if I have any further issues with the e brake down the road. |
tsvo Emergency brake Apr 7 2021, 06:22 PM
Dave_Darling Check to see if the cables are still attached to t... Apr 7 2021, 06:45 PM
tsvo
Check to see if the cables are still attached to ... Apr 7 2021, 06:51 PM
tsvo
Check to see if the cables are still attached to ... Apr 8 2021, 06:27 PM
bdstone914
Check to see if the cables are still attached to... Apr 8 2021, 06:43 PM
pcdarks You have a single cable about 8 inches long that t... Apr 7 2021, 07:02 PM
tsvo
You have a single cable about 8 inches long that ... Apr 7 2021, 07:11 PM
tsvo
You have a single cable about 8 inches long that ... Apr 8 2021, 06:27 PM
Olympic 914 May also need to set the air gap on the pads.
.00... Apr 8 2021, 05:51 PM
tsvo
.0... Apr 8 2021, 06:26 PM
Spoke Did the ebrake ever work or is this a new issue? Apr 8 2021, 06:58 PM
tsvo
... Apr 8 2021, 07:08 PM
bbrock
Did the ebrake ever work or is this a new issue?... Apr 8 2021, 07:51 PM
tsvo
[quote name='tsvo' post='2906644' date='Apr 8 202... Apr 8 2021, 08:04 PM
bbrock
[quote name='tsvo' post='2906644' date='Apr 8 20... Apr 8 2021, 09:54 PM
Dion Visual aide Apr 9 2021, 04:41 AM
tsvo
Visual aide
That is absolutely it. Mine is not ... Apr 9 2021, 05:25 AM
ClayPerrine
That is absolutely it. Mine is not connected. Se... Apr 9 2021, 05:55 AM
tsvo
That is absolutely it. Mine is not connected. S... Apr 9 2021, 06:11 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th September 2026 - 12:39 PM |
