| adolimpio |
Apr 7 2021, 05:10 PM
Art ![]() ![]() Group: Members Posts: 190 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States
I finished building my engine, which uses a 2.0 crank in a 1.7 case.
My crank end play is 0.0125 without any shims. I've seen that you should use a minimum of 3 shims, but even a single smallest shim puts me at the edge of spec - 0.0125 - .00945 = 0.003. Is this OK? Did I do something wrong assembling? |
| iankarr |
Apr 9 2021, 08:53 AM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,603 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Wow...just checked the type 4 store. You're right...7 bucks each. Sheesh. I wonder what happened to crank those up.
Alright then...Put two of your existing shims in and measure. Calculate the end play with those two shims and subtract .004 thou (your target play). If that number is less than .015 (or .38mm...which is the thickest one available), you may only need to buy one shim, depending on where that number falls in the available thicknesses. Make sense? Depending on what number you come up with, I may have one in my stash that you can have... |
| 02loftsmoor |
Apr 11 2021, 08:24 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region
Wow...just checked the type 4 store. You're right...7 bucks each. Sheesh. I wonder what happened to crank those up. Alright then...Put two of your existing shims in and measure. Calculate the end play with those two shims and subtract .004 thou (your target play). If that number is less than .015 (or .38mm...which is the thickest one available), you may only need to buy one shim, depending on where that number falls in the available thicknesses. Make sense? Depending on what number you come up with, I may have one in my stash that you can have... I didn't know about your videos , dang watching them now !! |
adolimpio Flywheel / crank end play Apr 7 2021, 05:10 PM
Bleyseng Did you set the end play before installing the rea... Apr 7 2021, 08:23 PM
adolimpio Yes, seal is not installed yet. Apr 7 2021, 09:19 PM
adolimpio Problem solve, it was caused by the DACO.
I'm... Apr 8 2021, 04:35 PM
02loftsmoor I'm replacing the Flywheel .
i have Three .010... Apr 8 2021, 08:47 PM
Mark Henry
i have Three .01... Apr 9 2021, 09:56 AM
02loftsmoor
i have Three .0... Apr 9 2021, 06:59 PM
iankarr The shims are available in a range of sizes. You... Apr 8 2021, 09:02 PM
02loftsmoor
The shims are available in a range of sizes. You... Apr 8 2021, 09:19 PM
Mark Henry When you get the shims be sure to test fit first. ... Apr 10 2021, 06:13 AM
02loftsmoor
When you get the shims be sure to test fit first.... Apr 11 2021, 08:18 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th September 2026 - 11:52 PM |
