| Penny |
Apr 10 2021, 11:18 PM
Newbie ![]() Group: Members Posts: 3 Joined: 10-April 21 From: Vancouver Member No.: 25,420 Region Association: None |
Hi guys, I’m new here and have a question. Took my 75 2.0 for a 45 minute drive yesterday and it ran like a top. (FYI 55 degrees yesterday.) Jumped in the car to come back home a half an hour later and it wouldn’t restart. Plenty of fuel. First thing I checked was fuel pump relay and it was fine. It wouldn’t even turn over nor any clicks like a dead battery. Nothing. But Radio, lights, etc. all worked. Neighbor eventually came over to give me a jump, then it turned over (could have been simply because it had cooled somewhat by then) but wouldn’t start. Oh, I put in a brand new battery last summer, so it shouldn’t be battery related, I don’t think. While I was waiting for the tow truck, tried to start it again after it had cooled more, about 2 to 2 1/2 hours after initially parked, and it started up perfect. Drove it home. Ran perfect on the way home. Parked safely in garage, turned it off and immediately tried to restart. Nothing, again wouldn’t even turn over. Went out to the garage three hours later, after it cooled, and started with the first turn on the key. Any ideas what I should be looking for?
| SirAndy |
Apr 11 2021, 09:07 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Sounds like your starter is failing.
I replaced mine with a high torque aftermarket one many years ago and never looked back. (IMG:style_emoticons/default/smile.gif) PS: (IMG:style_emoticons/default/welcome.png) |
| ClayPerrine |
Apr 11 2021, 01:57 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Sounds like your starter is failing. I replaced mine with a high torque aftermarket one many years ago and never looked back. (IMG:style_emoticons/default/smile.gif) PS: (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/agree.gif) The high torque starters are an easy, lightweight fix. If you want a stock starter, Porsche superseded all of the old air cooled starters to one new version that spins the engine really fast and doesn't suffer from the hot start issue. I have the high torque starters on two of our 914s, and the factory six has the new Bosch starter. They both work great. And.... (IMG:style_emoticons/default/welcome.png) Clay |
Penny Won’t start after running awhile. Apr 10 2021, 11:18 PM
Shivers Best fix I've seen.
http://www.914world.com/b... Apr 11 2021, 04:41 AM
Tdskip First of all welcome to the forum @Penny .
Hot s... Apr 11 2021, 08:53 AM
Penny Thank you so much, guys! Apr 11 2021, 09:39 AM
Mark Henry I'll never understand the logic of hating the ... Apr 11 2021, 02:52 PM
Penny If I knew my way around motors better, I would pro... Apr 12 2021, 11:06 PM
ClayPerrine
If I knew my way around motors better, I would pr... Apr 13 2021, 05:43 AM
BeatNavy
If you are going the aftermarket gear drive start... Apr 13 2021, 06:34 AM
Superhawk996
I’ve been stranded in BFE 4 times in the six ye... Apr 13 2021, 06:15 AM
VaccaRabite I'm a big fan of adding a relay to the starter... Apr 13 2021, 07:21 AM
StarBear Yep; did the relay and the Ford starter (bolted ri... Apr 13 2021, 08:33 AM
wonkipop
Yep; did the relay and the Ford starter (bolted r... Apr 13 2021, 08:32 PM
Mark Henry
Yep; did the relay and the Ford starter (bolted ... Apr 14 2021, 06:25 AM
wonkipop
[quote name='wonkipop' post='2907883' date='Apr 1... Apr 15 2021, 03:59 AM
StarBear PS: Before doing the aforementioned mod, one trick... Apr 16 2021, 06:44 AM
boxster914 So I'm having a hot start issue with my '7... Jun 12 2021, 08:28 PM
wonkipop seat belt interlock relay? hides under the passe... Jun 13 2021, 04:09 AM
BeatNavy Of the three most likely root causes, here's h... Jun 13 2021, 05:26 AM
Jett
Of the three most likely root causes, here's ... Jun 13 2021, 09:19 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:50 PM |
