> please help refresh my memory, clutch questions... thanks
brant
post Dec 29 2004, 01:12 PM
Sorry, I just needed to run this by someone.
I'm looking at buying a used flywheel that was run on a 71.. 6bolt.. 911 motor
seller said he ran it with a 225mm clutch application.
Am I correct in remembering that a stock 914 clutch is actually 215mm?
Is the 225mm application the one where you invert the tranny to a pull clutch?
just want to make sure I don't buy something that won't fit...
thanks all
brant
ClayPerrine
post Dec 29 2004, 03:49 PM
225 MM is a pull type clutch. To use it with a 901, you have to have the correct shift fork, throwout bearing, and clutch disk from a 70-71 911. You have to move the pivot point 14mm outboard, and use the reinforced pivot pin, not the stock one.
The upside is you get rid of the clutch pulley.
- Lo-Fi Version Time is now: 11th July 2025 - 07:25 AM
