> Throw out bearing installation question, shift fork cup bearing fit - how tight should it be on the ball?
DRPHIL914
post Apr 20 2021, 07:14 AM
Dr. Phil
I guess my question is how tight should it be? it rides on the outside and it seems the ball should be all the way into the cut and fork, so it feels like i will have to force it onto this to get it to seat, is it ok to tap it with the rubber hammer to get it seated on the ball?
my transmission is back together and once this TO bearing and fork are installed its ready to go back into the car!!!!
Mark Henry
post Apr 20 2021, 07:18 AM
that's what I do!
Tight but still a slip fit, make sure there's no rust and crud still in the hole.
DRPHIL914
post Apr 20 2021, 07:48 AM
Dr. Phil
QUOTE(Mark Henry @ Apr 20 2021, 09:18 AM) *
Ok i will clean that out make sure of that and clean off the ball, add a little grease or lube?
one other question i have too, the u bracket that holds the fork to the ball , the retainer that slides behind the ball, does the rounded side go behind the ball , facing the ball out toward the fork correct?
- Lo-Fi Version Time is now: 16th June 2024 - 07:41 PM
