Can this charcoal filter be refilled? |
advman89 |
Apr 26 2021, 02:09 PM
Member Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest |
mepstein |
Apr 26 2021, 09:05 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I don't have the patience or skill of bbrock. I'm also lazy. I used a 1.5" hole saw to open a hole on the bottom, dumped out charcoal, refilled it and sealed it back up with a piece of duct tape. Once it's mounted on the gas tank, the duct tape isn't visible. !0-15 minutes.
bbrock |
Apr 26 2021, 09:20 PM
I don't have the patience or skill of bbrock. I'm also lazy. I used a 1.5" hole saw to open a hole on the bottom, dumped out charcoal, refilled it and sealed it back up with a piece of duct tape. Once it's mounted on the gas tank, the duct tape isn't visible. !0-15 minutes. Curious how you dealt with the sandwich of spring loaded screens and filters. That was the only problem I had with the drill method, but it was a big one. I guess with a 1.5" hole, you could probably get the springs and sandwich re-positioned before refill? |
mepstein |
Apr 26 2021, 09:38 PM
I don't have the patience or skill of bbrock. I'm also lazy. I used a 1.5" hole saw to open a hole on the bottom, dumped out charcoal, refilled it and sealed it back up with a piece of duct tape. Once it's mounted on the gas tank, the duct tape isn't visible. !0-15 minutes. Curious how you dealt with the sandwich of spring loaded screens and filters. That was the only problem I had with the drill method, but it was a big one. I guess with a 1.5" hole, you could probably get the springs and sandwich re-positioned before refill? Yes. I don't remember the exact size of the hole saw but I was able to hold the internal pieces in place long enough to get it mostly filled and then packed some more in. I might have used something to wedge the parts in place. It was a while ago. I was thinking the next time I would use a hole saw the same size as the rubber disks that close off the holes in the front trunk. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:30 PM |
