> Which Vendor wants to jump on making these..., 022115542
JamesM
post Aug 19 2020, 07:02 PM
What would it take to get one of our vendors to make these?
022115542 - crank case valve
Surprisingly critical part for proper operation on 72-74 djet cars, not just for crank case venting but has a large impact on idle control and how d-jet runs. Supposed to be a regular maintenance/replacement item as well yet they haven't been available for close to 20 years. Struggling to find any that don't result in some sort of idle control issue these days.
Less critical is the associated nut 022115544
@Mikey914 @UROpartsman or anyone else want to bite?
post Apr 27 2021, 03:24 PM
Someone did a write up here about a suitable replacement for that NLA part. Might have been a Toyota product? He had been chasing his tail with a high idle problem before he found this part. Sorry but I don't remember who posted it!
Not_A_Six
post Apr 27 2021, 03:57 PM
QUOTE(76-914 @ Apr 27 2021, 02:24 PM) *
That sounds like me. (IMG:style_emoticons/default/biggrin.gif)
Check post #3 at the beginning of this thread.
Here's the link again:
http://www.914world.com/bbs2/index.php?act...=2&t=347986
Cheers. (IMG:style_emoticons/default/beerchug.gif)
dax1969
post Apr 28 2021, 02:06 AM
QUOTE(Not_A_Six @ Apr 27 2021, 11:57 PM) *
Found that thread earlier and was excited to see a solution .... got worried and backed out when DRPHIL914 jumped in and created a leak ...
Do you still run the Toyota PCV valve with no issues ? Idle ok, no leaks ?
thks yr feedback
Dax
Not_A_Six
post Apr 28 2021, 10:15 AM
QUOTE(dax1969 @ Apr 28 2021, 01:06 AM) *
thks yr feedback
Dax
Yep. I still run it without any problems. I did swap the electrical tape for some heat shrink tubing as was suggested by bob164. Looking at that thread again, it seems that DRPHIL's issue was that his '75 didn't have a return line to the crankcase through an anti-flashback valve. So plumbing the breather box to the plenum instead of the air filter depressurized the crankcase and caused...something...to leak.
At this point, I can say that the Corolla PCV valve seems to work really well in a '73 2.0, with the rest of the system plumbed like Bowlsby's diagram. If you have some other engine, or some other model year, or some other hose routing, you may have issues.
If you currently have a hose running from the breather box to the air filter box, you can't just splice in a PCV valve and run the hose to the plenum instead. You need the whole system per Bowlsby.
JamesM   Which Vendor wants to jump on making these...   Aug 19 2020, 07:02 PM
914werke   Ummm Unless this is concours thing :confused:   Aug 19 2020, 07:13 PM
JamesM   [url=http://www.914world.com/bbs2/index.php?s=...   Aug 19 2020, 09:50 PM
Not_A_Six   What would it take to get one of our vendors to m...   Aug 19 2020, 07:39 PM
914werke   :D   Aug 19 2020, 08:12 PM
davep   Can you post a photo?   Aug 19 2020, 10:13 PM
JamesM   Can you post a photo?   Aug 20 2020, 12:17 AM
Mikey914   Happy to take a look at these this next week. I...   Aug 20 2020, 12:03 AM
JamesM   Happy to take a look at these this next week. I...   Aug 20 2020, 12:31 AM
JamesM   Was gone over in depth long ago on STF but for som...   Aug 20 2020, 01:00 AM
Not_A_Six   Was gone over in depth long ago on STF but for so...   Aug 20 2020, 10:35 AM
UROpartsman   We've had this item on the "maybe" l...   Sep 14 2020, 10:49 AM
JamesM   We've had this item on the "maybe" ...   Sep 14 2020, 09:37 PM
914Sixer   I should have a used one in the warehouse.   Sep 14 2020, 12:10 PM
UROpartsman   I should have a used one in the warehouse. Thanks...   Sep 17 2020, 11:45 AM
Mikey914   Ok, Had started drawings on this, but if URO wants...   Sep 14 2020, 01:07 PM
second wind   So...is there a good way to service these little s...   Sep 14 2020, 05:45 PM
second wind   Cleaned my existing one.....seems to function just...   Sep 17 2020, 10:58 PM
Eric_Shea   Find someone that knows how to put a modern EFI sy...   Sep 18 2020, 09:42 AM
second wind   Well...I said I would report back not that anyone ...   Sep 18 2020, 05:33 PM
Mikey914   I'm happy you were able to resolve the problem...   Sep 19 2020, 06:39 PM
UROpartsman   Mark says his valve isn't in the best conditio...   Sep 22 2020, 01:17 PM
UROpartsman   We found a good sample, thanks guys. Currently ev...   Nov 12 2020, 03:49 PM
dax1969   Hi there, Any news on this ? No idea if mine is ...   Apr 23 2021, 06:39 AM
bdstone914   Hi there, Any news on this ? No idea if mine is...   Apr 23 2021, 08:31 AM
dax1969   [quote name='dax1969' post='2910293' date='Apr 23...   Apr 26 2021, 01:47 AM
bdstone914   [quote name='dax1969' post='2910293' date='Apr 2...   Apr 28 2021, 03:15 PM
UROpartsman   Hi there, Any news on this ? We're currently ...   Apr 23 2021, 10:08 AM
JamesM   Hi there, Any news on this ? No idea if mine is...   Apr 26 2021, 05:55 PM
Mark Henry   Likely mentioned already, but there's also a p...   Apr 23 2021, 10:33 AM
FlatSix   Likely mentioned already, but there's also a p...   Apr 24 2021, 01:18 AM
Not_A_Six   Likely mentioned already, but there's also a ...   Apr 26 2021, 10:04 AM
76-914   Someone did a write up here about a suitable repla...   Apr 27 2021, 03:24 PM
Not_A_Six   Someone did a write up here about a suitable repl...   Apr 27 2021, 03:57 PM
dax1969   Someone did a write up here about a suitable rep...   Apr 28 2021, 02:06 AM
Not_A_Six   Found that thread earlier and was excited to see ...   Apr 28 2021, 10:15 AM
76-914   That's it. I bookmarked it this time. THX. :be...   Apr 27 2021, 04:08 PM
pbanders   @UROpartsman , any update on PCV valves? I guaran...   May 8 2022, 12:35 PM
UROpartsman   [b]@[url=http://www.914world.com/bbs2/index.php?s...   May 16 2022, 04:39 PM
euro911   So they're only applicable on '72 & la...   May 8 2022, 12:44 PM
JamesM   So they're only applicable on '72 & l...   May 16 2022, 11:35 AM
- Lo-Fi Version Time is now: 19th July 2025 - 10:26 AM
