| DC_neun_vierzehn |
May 8 2021, 04:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 640 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
I have a '73 2.0.
I purchased a Blaupunkt Frankfurt radio to replace the original radio (well it was the original Sapphire, but it's definitely an early 70's radio and fit into the dash plate like a Sapphire). I removed the old radio from the dash. When I try to drop in the Blaupunkt into the plate, the center window hole appears to be too small for the Blaupunkt. Seems like it's about a mm or two too small. Anybody else ever encountered this when trying to install a Blaupunkt Frankfurt? Do I need to get a different dash plate for the Blaupunkt Frankfurt? Is there a different plate available anywhere? I'd rather not file or dremel the hole bigger. |
| 914Sixer |
May 9 2021, 11:09 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,453 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
So what your saying is the Dash piece is too small , NOT the faceplate shown here. Sapphire dash plate is plastic, the Blaupunkt is metal.
DC_neun_vierzehn Blaupunkt Frankfurt radio fitment issue? May 8 2021, 04:06 PM
914Sixer This is what your plate should look like. Round n... May 8 2021, 06:24 PM
DC_neun_vierzehn
This is what your plate should look like. Round ... May 8 2021, 09:22 PM
Mike Fitton I believe he is talking about the dash plate openi... May 8 2021, 08:00 PM
Mike Fitton Post a picture of your radio with the chrome trim ... May 9 2021, 05:57 AM
DC_neun_vierzehn
Post a picture of your radio with the chrome trim... May 9 2021, 08:28 PM
914Sixer Sapphire plate is COMPLETELY different than Blaupu... May 9 2021, 06:11 AM
DC_neun_vierzehn The nose hole in the upholstered dash plate is too... May 9 2021, 09:31 AM
DC_neun_vierzehn
So what your saying is the Dash piece is too smal... May 9 2021, 04:01 PM
gereed75 These are made specifically for each radio. You c... May 9 2021, 07:40 PM
Mike Fitton That chrome piece will not work it is designed to ... May 10 2021, 02:22 PM
DC_neun_vierzehn
That chrome piece will not work it is designed to... May 11 2021, 02:01 PM
Mike Fitton
That chrome piece will not work it is designed t... May 11 2021, 03:06 PM
Mike Fitton You could also use the faceplate you have in post ... May 10 2021, 02:25 PM
rfinegan I used the din mount on my Koln...
May 10 2021, 05:55 PM
DC_neun_vierzehn Dremeled the hole a couple of mms taller (off the ... May 15 2021, 08:40 AM
DC_neun_vierzehn 6 pin Bluetooth plugged into the back of the radio... May 15 2021, 08:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:22 AM |
